06-10-2010, 05:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: .::Gsm::.
Member: 1081011 Status: Offline Sonork: 100.1594100 Thanks Meter: 463 | .::: 3110c Blinking After Nokia Logo ::. I check to mxkey, mtbox, ufs, jaf but no boot on any box.......... |
06-10-2010, 05:30 | #2 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
did u try erase flash backup crt with uFS+HWK then try to unsafe erasing with mxkey flash it 7.30 version with ufs+hwk restore crt NCP only again to connect mxkey repair simlock and sd data write full pm(with out308) now phone security test allways failed just write CCC&HWC GOOD LUCK POST RESULT | |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
06-10-2010, 06:50 | #7 (permalink) | |
@ .::adnan440::. Check this picture | |
06-10-2010, 07:22 | #9 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | why change tahvo? Answer------------tahvo generated by vcore volt same problem faced symbian phone change smps becoz smps generated by vcore volt vcore volt droping or missing time phone show nokia logo only 3110c is jave based phone not using smps,this same function managed by tahvo but remmber handfree manager ic make this same problem thats why i asking remove that ic :d |
06-10-2010, 08:24 | #10 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Wish i was on Mars Age: 40
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | Quote:
Br frenzy | |
06-10-2010, 11:04 | #11 (permalink) | |
tahvo chance only 35% i done above 1000 bb5 phone hardware CS | |
06-10-2010, 12:55 | #13 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | listen dear friends this i managed this methode (JAVA Based Phone) 1)Connect software&flash lastest version 2)After flash same problem faced 3)Take CRT backup try unsafe erasing and flash it lastest version again 4)Restore only NCP data,repair simlock and sd data,upload full pm now phone security test allways failed---JUST write CCC&HWC (Symbian Based phone) FOrmat user area and full factory rest second try above methode HARDWARE PROBLEM JAVA BASED PHONE 1)PROPER TO CLEAN PCB MAINLY POWER SECTION 2)REMOVE HANDFREE DRIVER IC(BECOZ THIS IC WORKING VOLT GIVE RETU) 3)CHECK VCORE VOLT OUT PUT(1.4V) 4)VOLT DROPED OR MISSING?TAHVO PROBLEM(CHANGE TAHVO) TAHVO GENERATED BY TAHVO 5)CHECK VIO VOLT VIO GENERATED BY RETU BUT REMMBER VIO VOLT BREAKED PHONE CANT POWER TOTALLY DEAD(BUT VIO VOLT DROPED PHONE FACED THIS PROBLEM) 6)VIO DROPED TIME FIRST CHECK VIO LINE FILTER CAPACITOR OR REMOVE IT 7)AFTER CHANGE TAHVO AND RETU PHONE FACED SMAE NOKIA LOGO? REFLOW OR REBALL RAP3G |
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
06-10-2010, 13:10 | #15 (permalink) |
Freak Poster Join Date: Feb 2007 Location: punjab
Member: 457143 Status: Offline Thanks Meter: 11 | mxkey can solve use fbus in service tab go to quick fix and select BB5 softeware fix and press do selected job. all is done |
The Following 2 Users Say Thank You to dildar baniya For This Useful Post: |
