04-24-2011, 12:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | 3110c cmt boot error(urgent) i recieved 3110c which was for input calculator set was ok. then i try to flash with usb but usb cant connect then i try with hwk fbus cable but when erasing mcu then shows cmt data error and now set is dead i try with mxkey skip erase only mcu but not success same i try with hwk ship erase same its too urgent plz help... |
The Following User Says Thank You to jimm07ct For This Useful Post: |
04-24-2011, 12:32 | #2 (permalink) |
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | in mxkey when i bus check then logg is here.. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2A40020859976D569BA7E8D7F9DC103946817EA8 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,CMT ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Original Imei: 00000000000000 Original Product code: |
04-24-2011, 12:33 | #3 (permalink) |
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | in hwk logg is here........ 1ST BOOT : C0,07 [Rm-237] [2.1.0.1] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 2A40020859976D569BA7E8D7F9DC103946817EA8 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 0020881C-00006A21, St M58LR256KC CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent PASUBTOC not Exists Rebooting Mobile |
04-24-2011, 12:36 | #4 (permalink) |
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | when i try to flash with hwk then shows data block error logg is here........ 1ST BOOT : C0,07 [Rm-237] [2.1.0.1] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 2A40020859976D569BA7E8D7F9DC103946817EA8 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 0020881C-00006A21, St M58LR256KC CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm237__07.21.mcusw_cal CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 00:03 DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_BLK_ERROR at: 0x00020000, 03 ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x000280, Time: 00:05 Process Failed, Repowering Mobile |
04-24-2011, 13:18 | #6 (permalink) |
No Life Poster Join Date: Aug 2004 Location: pakistan Age: 38
Member: 78884 Status: Offline Sonork: mohsin111 Thanks Meter: 92 | [IMG]http://1.bp.********.com/-Eg_hbJ07vYI/Taa-VEZgC0I/AAAAAAAAAg8/G5_VUCyG7aI/s1600/3110%2B%2526%2B6300%2B%2526%2B3500%2Btested%2Bsolu tion%2BERR%2BCMT%2B2ND%2BBoot%2BCERT%2BMismatch.jp g[/IMG] |
The Following User Says Thank You to Mohsin_josh For This Useful Post: |
04-24-2011, 15:20 | #9 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
04-24-2011, 15:47 | #10 (permalink) | |
Freak Poster Join Date: Apr 2011 Location: iloilo city
Member: 1561609 Status: Offline Thanks Meter: 9 | Quote:
05-03-2011, 07:52 | #14 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
First flash with jaf with good fbus cable 100% recovered your phone, then flash with cnt only in mxkey tool your problem solved themes calculator recovered, not solved contact me sonork or yahoo i can solv ur problem with team viewer.......... BR, Srinivas Reddy. | |
The Following User Says Thank You to swechacnu For This Useful Post: |
boot count problem | Devils-thoughts | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-06-2001 12:49 |
8810 & 8210 Phone NOT respond! (Load Boot data) | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-25-2001 14:47 |
F_loaders.bin and Boot.bin .. . | micklong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-29-2001 14:49 |
Phone not respond! (Load boot data) Need a help ! | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-23-2001 02:10 |
Phone dont respond ( boot count ) | galles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-31-2000 01:53 |
