Old 01-15-2010, 07:34   #1 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
Thanks Meter: 2,485
Arrow 1200 Failed! Aborting! Help need
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 98.95%
P-key nokia module version 01.02
Detected UFS_USB V2.6 (c) SarasSoft 2005. version: 01.B1, Driver version: 0, Library version: 0
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.17.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\
Searching for JAF saved location of ini...
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.000
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.00aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai4.00aa
Languages in ppm: English,Dannish,Norwegian,Swedish
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.000
Booting phone...
MCU ID: 0x2292
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 10011000 <=> Flash ID not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Flash ID is 0x6822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: 50
Loader is ready...
MSID: 846B846505627E940F274B9B8C
MSID decoded: 3E4EBAE90017341FAA000000
FAID: A9303C7A4FBA4077D5BB3638
Operation took 0 minutes 11 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 31 seconds...
Writing...
Permanent Data Restore FAILED!
Operation took 11 minutes 38 seconds...
Restarting MCU...
Failed! Aborting!
Old 01-15-2010, 07:40   #2 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
try do it with hwk and with other cable with higer ver . if same then its hardware problem . rehot flash ic . best of luck .
Old 01-15-2010, 07:46   #3 (permalink)
.::MAHABUB::.'s Avatar
Member: 939797
Sonork: 100.1601089
Thanks Meter: 359
try with easy cable.i hope that your problem willbe solved.many times tested by me.
Old 01-15-2010, 07:48   #4 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
1ST U CHECK ITS USB POINTS...... if there's any shorting remove it. then heat uem normally.......... it'll solve ur problem 1000000%.. But if then also no luck just heat upp and try flash again........ U'll get it done..done.....done.!!!!!!!!
Old 01-15-2010, 09:08   #5 (permalink)
jerrymamun2009's Avatar
Member: 1108551
Sonork: Jerry
Thanks Meter: 153
Just Change ur cable...
The Following User Says Thank You to jerrymamun2009 For This Useful Post:
Old 01-15-2010, 09:11   #6 (permalink)
rubel_chk007's Avatar
Member: 1085201
Thanks Meter: 1,222
Thumbs down
nokia 1200 full eroas..........& flash
Old 01-15-2010, 10:01   #7 (permalink)
Member: 1427033
Sonork: 100.1596688
Thanks Meter: 1,204
Originally Posted by abdurrahimsagar View Post
JAF version 1.98.62
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing...
Writing...
Restarting MCU...
Failed! Aborting!
Bro,flash with this rh99_04.110 or
RH-99_dp_v_37_00_MCUSW5_91
100% solved.
3110 flash failed aborting-help me matnuacai Nokia Base Band 5 ( BB-5 ) 20 05-06-2011 12:25
1200 failed aborting help me haigoshi Nokia Digital Core Technology 4 ( DCT-4 ) 3 02-17-2009 08:21
Page generated in 0.17365 seconds with 9 queries
