Old 03-13-2009, 07:11   #1 (permalink)
sigamani's Avatar
Member: 817776
Thanks Meter: 107
3110c flashing err?
3110c flashing err,,,,,,,,,,,,,,please help me,,,,,,,,,,thanks advance,,,,,,phone restarting problem,,,,,when we try flash by ufs+hwk,,,,it shows following err,,,,,,,,,
1ST BOOT : C0,07 [Rm-237] [2.0.8.0]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 1510011958667C56C9ECBDA77BC1EC81060BAF8C
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0
CMT FLID0 : 00898981-00000000, Int NU48F256
CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.40.0
CMT VPP : External
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm237__07.21.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 00:00
DATA_BLK_ERROR at: 0x00044400, 00
ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x004000, Time: 00:10
Process Failed, Repowering Mobile
The Following User Says Thank You to sigamani For This Useful Post:
Old 03-13-2009, 07:32   #2 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
Is it still running, goes local mode?
Restarting problem gets solved just by formating file system.
The Following User Says Thank You to nishaon For This Useful Post:
Old 03-13-2009, 07:46   #3 (permalink)
sandeep barwal's Avatar
Member: 315138
Thanks Meter: 56
it's cable prob. try 7 pin cable.............
Old 03-13-2009, 07:46   #4 (permalink)
Member: 70916
Thanks Meter: 55
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : External
DUAL LINE : True
CMT ALG Boot OK
for this flash chip Int NU48F256 u have to use ext vpp in ufs old r latest ver
do post result enjoy
Old 03-13-2009, 07:47   #5 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,510
3110c flashing err,
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : External
DUAL LINE : True
CMT ALG Boot OK
bro plz u r hwk upddate 2.0.8.2 version and flash u r phone i think u parolam 100% solved cheack and post rply
The Following 2 Users Say Thank You to ..::ohm::.. For This Useful Post:
Old 03-13-2009, 08:09   #6 (permalink)
Member: 70916
Thanks Meter: 55
i forget one thing u have to (9volts hw) battery, open u cable connect + to 2 pin which is spare pin - to the ground
1
2 (+ point of the battery)
3
4
5
6
7 (- point of the battery)
close the data cable & flash the phone rem use new batter
uif u have any dout buzz me [email protected]
Old 03-13-2009, 08:29   #7 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
Please don't use external power or battery, it damage ur phone physically.
Old 03-13-2009, 09:09   #8 (permalink)
Member: 753880
Thanks Meter: 10
try use another box
some time i use hwk oso can't flash
Old 03-13-2009, 09:30   #9 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 436
use jaf & 7pin cable..v7.xx ur problem solv 100% ......bro:s
Old 03-13-2009, 09:31   #10 (permalink)
masum_sohel's Avatar
Member: 852543
Thanks Meter: 2,338
change ur flash cable then flash again
The Following 2 Users Say Thank You to masum_sohel For This Useful Post:
Old 03-13-2009, 11:38   #11 (permalink)
Member: 993503
i try use another box
i used J.F.A box
th
Old 03-13-2009, 14:22   #12 (permalink)
kathir.'s Avatar
Member: 880497
Thanks Meter: 193
i have a 3110 ,it is hanging with nokia, do i have to flash or any hardware problem? i tried to flash but not boot ok plz help me...
Old 03-13-2009, 14:55   #13 (permalink)
Member: 662678
Thanks Meter: 2,510
3110
bro. 3110 bro. 7.21 use flash with jaf u r paroblam 100% solved
Old 03-14-2009, 09:04   #14 (permalink)
Member: 70916
Thanks Meter: 55
no dude it will not damage u mobile i am facing same problem for new chip for only new chip u have to use external power other wise it will not flash u can try in any box ufs,jaf,mt.
when u face the problem u will know it
first check wheather my solution work r not, i have succesfully solved this type of prob nearly 15sets all r ok
note use extpower only for this new chip only Int NU48F256
do post results
Old 03-15-2009, 13:59   #15 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
do post results
yes dear you are rightInt NU48F256 in this chip work only extarnal vpp
without ext power not flash
3110c flash err....... rafiqcell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 03-01-2010 14:55
3110C flas universal box error!!! mxkey 3110c flash ok ok ok succesfully mathew_di MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-22-2010 19:08
3110c flashing err sigamani Nokia Hardware & Hardware Repair 1 03-21-2009 11:28
3110c writte err sigamani Nokia Hardware & Hardware Repair 6 02-16-2009 11:08
Page generated in 0.44859 seconds with 8 queries
