Old 11-12-2009, 08:23   #1 (permalink)
Member: 1055536
Thanks Meter: 24
3110c flashing error plaese help me datamissmatching rx2 pin not connected used 5pin
used 5pin data blk error please help me
Old 11-12-2009, 09:35   #2 (permalink)
GSM HABIBI's Avatar
Member: 912688
Sonork: 100.1623116
Thanks Meter: 181
use 7 pin cable brother problem will be solved and post you logs
Old 11-12-2009, 09:40   #3 (permalink)
Member: 1055536
Thanks Meter: 24
i used 7 pin cable but same problem
Old 11-12-2009, 09:45   #4 (permalink)
GSM HABIBI's Avatar
Member: 912688
Sonork: 100.1623116
Thanks Meter: 181
post here your logs please
Old 05-02-2010, 13:18   #5 (permalink)
Member: 563368
Thanks Meter: 4
3110c data blk error........ log files
1ST BOOT : C0,07 [Rm-237] [2.1.0.0]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 09300105749D7C56314E5C97A2E8380577BDE8F8
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898981-00006A21, Int NU48F256
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm237__07.21.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 01:29
DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable !
DATA_BLK_ERROR at: 0x01060400, 03
ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x000240, Time: 02:24
Process Failed, Repowering Mobile
Old 05-02-2010, 13:24   #6 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
use any other box to flash..ufs is crap
Old 05-02-2010, 13:48   #7 (permalink)
Member: 812422
Thanks Meter: 18
use jaf software with ufs your pro solve
Old 06-30-2010, 08:41   #8 (permalink)
Member: 341386
Sonork: 100.1647322
Thanks Meter: 37
IT is flash IC problem...wont solve with data cable
Old 06-30-2010, 09:09   #9 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
just flash with jaf as interfase to mxkey
Old 07-01-2010, 05:54   #10 (permalink)
Member: 1083123
Sonork: 100.1594766
Thanks Meter: 567
just flash by usb cable your problem must be solve
Old 07-01-2010, 06:36   #11 (permalink)
Member: 1300401
Sonork: 2+2=4
Thanks Meter: 16
dear brother use ufs "ext vpp" tick and flashing . your problem solved
Old 10-31-2011, 11:00   #12 (permalink)
Member: 1674078
thanxxxxxxxxxxxx firosnbr brother
Old 10-31-2011, 11:18   #13 (permalink)
Member: 1680941
Sonork: +91-7567507692
Thanks Meter: 21
just flash usb cable with mx key and post log here
Old 10-31-2011, 11:25   #14 (permalink)
gtm_gtm's Avatar
Member: 1385520
Sonork: 100.1616989
Thanks Meter: 14
use mxbox ......
First uncheck cnt and ppm. Skip erase. Flash. Then uncheck mcusw. Uncheck skip erase and fast flash. Unlock. Thats all. Enjoy .
Old 11-02-2011, 12:41   #15 (permalink)
shafi_136's Avatar
Member: 1497712
Thanks Meter: 82
just for fbuse cable anther cable 100% testted
3110c DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! problem solved 100% gsm junction Nokia Base Band 5 ( BB-5 ) 4 09-05-2014 17:58
3110c DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! problem solved 100% Moiz Khan Nokia Base Band 5 ( BB-5 ) 3 02-10-2010 13:30
Page generated in 0.39915 seconds with 8 queries
