Old 11-14-2009, 07:08   #1 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
Arrow 3110c MCU flashing data block error
hello every body i have one 3110c when i am flash with MX key 7.21 verson is successful but by mistake i am another time flash with 7.01verson when flashing proccess start, i am manualy abort operation then i am another time flash 7.21verson its show data error when MCU flashing 20% complete ,PCB is clean mean no watter damage no one service the whole phone here its complete Log pls pls help me I am wating .
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Processing file: rm237__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM1 ID: 00000232
EM2 ID: 00000353
PUBLIC ID: 12B0010B2AB47C5667BACE697A67757B96025AA7
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Erase skipped.
Flash programming ...
Valid PAPUB key found
CMT PAPUBKEYS, RAP Certificate 66 v2 written.
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00480400, Result: 0010
Flashing terminated with error(s) in 47.516 s
RX Buffer: C7012D0103CD000010000000F172
The Following User Says Thank You to asmanju08 For This Useful Post:
Old 11-14-2009, 07:11   #2 (permalink)
s.s.s.s.'s Avatar
Member: 988641
Sonork: sanjay chaudhary
Thanks Meter: 342
bro,
use hwk .....
erase flash and then flash with 7.21 ver........
Old 11-14-2009, 07:14   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,374
RAP Data :
EM1 ID: 00000232
EM2 ID: 00000353
ASIC MODE ID: 00
Erase skipped.
Bro.try to jaf use 7pin cable & agin flash.
many time hwk this problem.
result post here.
Old 11-14-2009, 07:49   #4 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 270
Erase skipped.
hi dude...
hardware error....
rehot or reball flash.
Old 11-16-2009, 15:16   #5 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
result post here.
Problem still same............................
Old 07-13-2010, 09:20   #6 (permalink)
naveed ali's Avatar
Member: 720264
Sonork: 100.1649278
Thanks Meter: 170
Old 02-16-2011, 12:20   #7 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 942
yes his problem in cable 100% he is using 5 pin cable dear you must use 7 pin cable. or use usb cable .
Good Luck!
Old 02-16-2011, 12:31   #8 (permalink)
Ravvi's Avatar
Member: 611165
Thanks Meter: 36
its cable probelm ps chk the cable ya try with usb
3110c MCU flashing data block error asmanju08 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 11-14-2009 16:36
Bb5 Flashing Data Blk Error kankandeka Nokia Base Band 5 ( BB-5 ) 0 05-18-2008 20:34
Page generated in 0.32954 seconds with 8 queries
