12-01-2008, 20:48 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 677078 Status: Offline Thanks Meter: 9 | 3110c with power supply, power on is ok. but with battery can't power on. i have 3110c water damage phone. after i clean the circuit board, i got a weird problem. when i press the on/off button (with power supply 3,6 v connected to phone) it can power on. but when i attach the battery to phone, it can't power on when i press power on/off button. (note, battery full of charge) this is happened even there is simcard inserted and not inserted. i had check the on/off switch button.. and it is ok (no line cutted so i don't have to make a jumper wire for this button) battery connector is in good condition and clean.. please sombody.. help me.. |
The Following User Says Thank You to unnang For This Useful Post: |
12-01-2008, 21:44 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Estonia Age: 37
Member: 154612 Status: Offline Thanks Meter: 824 | Seem`s like shorted circuits and phone is eating too much current. try reflowing all BGA`s with flux... i hope it help. BR Janar |
The Following User Says Thank You to janar_jk For This Useful Post: |
12-04-2008, 22:32 | #3 (permalink) |
Member: 677078 Status: Offline Thanks Meter: 9 | 3110c BSI Faulty, on with adapter but not with battery thanks bro. but i had solve it. that's a short circuit in BSI line. i change R2213 (4K7 R) with R206 from nokia 3100, and it works. it can charge normally too.. Note. check the temp line too.. for my case, temp line is in good condition. all working perfectly now. thanks again bro. |
n81 lcd on charger ok but when power on black screen | ms.4011 | Nokia Hardware & Hardware Repair | 3 | 12-03-2009 04:18 |
1112 software is ok but set not power on help me plz | shani72 | Nokia Hardware & Hardware Repair | 12 | 06-22-2009 13:04 |
3230 flash is ok but no power on | hasanphone | Nokia Hardware & Hardware Repair | 1 | 02-02-2008 08:38 |
nokia 7210 on software ok but dose not power on | mobilecitycbk | Nokia Hardware & Hardware Repair | 3 | 05-10-2007 10:56 |
i have problem in K700 if i turn off ok but if i will power on not response | gsm4libya | Cruiser Suite | 0 | 04-28-2006 21:44 |
