Old 08-07-2008, 12:50   #1 (permalink)
Registered User
Member: 645764
Thanks Meter: 208
2626 phone restricted problem
i flash in latest version in jaf ,but still same problem any methed to flash.................without sim working & ime ok
The Following User Says Thank You to ka jagan For This Useful Post:
Old 08-07-2008, 13:02   #2 (permalink)
VHINTECH's Avatar
Member: 810940
Thanks Meter: 21
did you try to unlock the phone?
post logs here....
Old 08-07-2008, 13:05   #3 (permalink)
Bharat Dhingra's Avatar
Member: 620594
Thanks Meter: 38
You need to unlock phone .
If you have already flash the phone than , just press unlock button,
JAF will ask you for MCU file.
put same MCU which you have flahed
( Remember : Same version . This is must. otherwise you will loose your phone )
Hardly. less than 1 minute procedure and your phone is unlock.
Just try.
Old 08-07-2008, 13:06   #4 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
@ka jagan
Make unlock job mate.post log
Old 08-07-2008, 13:06   #5 (permalink)
Member: 571857
Thanks Meter: 20
only pm file write and 10000000% ok
Old 08-08-2008, 10:16   #6 (permalink)
Registered User
Member: 645764
Thanks Meter: 208
already i do it any other solution..............................
Old 08-08-2008, 12:04   #7 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
@ka jagan
which gadget you are using ??????????? and post log here
Old 08-08-2008, 12:11   #8 (permalink)
Member: 598303
Thanks Meter: 7
erase flash and flash then unlock it will work
Old 08-08-2008, 14:00   #9 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
dear brother only pm file write and 10000000% ok
Old 08-08-2008, 15:38   #10 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Only unlock the phone your problem were solved.
Old 08-09-2008, 07:17   #11 (permalink)
Member: 620594
Thanks Meter: 38
Please Post your log here first. Than may be other can find good solution for you
Old 08-14-2008, 17:10   #12 (permalink)
murthyy's Avatar
Member: 265133
Thanks Meter: 285
i also have the same problem
i flashed it with 6.80 version with JAF
wrote gud pm ,did factory settings ,unlocked it
but problem remains same
board is clean no water damage or physical damage
here is the log
Powering the phone...
Unlocking...
IMEI: 358087015112100
ASIC: b
SW version: 06.80
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 01
MCU ID: 0x3040
Algo is ready...
P-key nokia module version 01.02
Erasing area: 010A0000 - 010BFFFF...
Unlocking...
Phone is not in LOCAL MODE or TEST MODE, or imei is damaged...
Failed! Aborting!
solutions please thank you
Old 08-14-2008, 20:16   #13 (permalink)
Member: 675717
Thanks Meter: 125
First erase flash>flash with update version >write pm>unlock use same MCU file you can use Jaf/Mt if not ok ask for rpl.
Old 08-15-2008, 07:38   #14 (permalink)
murthyy's Avatar
Member: 265133
Thanks Meter: 285
problem solved
i erased flash and full flashed
wrote pm and unlocked it
now phone is ok
thanks to all
The Following User Says Thank You to murthyy For This Useful Post:
6233 network problem pm write but phone restricted problem please help me micro_hsr Nokia Base Band 5 ( BB-5 ) 4 10-23-2008 10:55
2626 phone restricted ka jagan Nokia Hardware & Hardware Repair 11 05-18-2008 15:45
nokia3120 phone restricted problem Adityaram Nokia Hardware & Hardware Repair 2 11-07-2007 11:02
Page generated in 0.18357 seconds with 9 queries
