01-12-2010, 05:16 | #7 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 950964 Status: Offline Thanks Meter: 161 | if your fone is detected than read the code with jaf if code is active than usb not work brother you r tring with fbus cable if your problem is still full flash with ui setting your fone is ok |
01-12-2010, 06:18 | #10 (permalink) | |
Freak Poster Join Date: May 2007 Location: Inside You
Member: 513210 Status: Offline Thanks Meter: 110 | Quote:
in that sitution..... if you are sure that your cable is good... its hardware problem... mild reflow thavo....becuase thavo ic is holding the pin out flashing connectivity...... | |
01-12-2010, 06:29 | #11 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
100% cable internal resistance problem set not coming in test mode use TMA adopter problem will be solved | |
01-12-2010, 06:33 | #12 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | Quote:
1 open jaf software......slect USB mode 2 power On set with power supply...with RED..GREEN..BLACK 3 set will goto direcct local mode 4 insert usb cable and do the jab if helpfulll dont forget to say thaxxxx | |
3110c Security Code! | Harisk | Nokia Base Band 5 ( BB-5 ) | 13 | 08-15-2011 10:38 |
3110c security code | umesh garg | HWK | 12 | 09-05-2008 17:16 |
3110c Security Code | damabib | J.A.F. By Jafsupport.com | 3 | 12-08-2007 20:34 |
