3120/3100 strange audio problem I found 10 pieces of 3120 when you call 112(emergency call) you can hear from speaker and police hear from me but when you call other number you won't hear anything from yhte speaker and nothing to mic too someone can hear i use to flash but no solution.ok simply works on audio when you use 112 only |
Check UPP, if is 835 u must change to 82xx. B.R Vinh Hai |
[QUOTE=VinhHai]Hi, Check UPP, if is 835 u must change to 82xx. Thankz VinhHai can you bring the service manual so can proper see 835 and from 82xx proper value exchange |
1 Attachment(s) [quote=mkwatis] Quote:
UPP 82xx use for 6610, 3100/20 B.R Vinh Hai |
1 Attachment(s) it's software problem just make full flash then write this pm file |
good man let me try Quote:
i test it many time before |
hi, mates try this solution: just write pp... 100% working post result...:) |
hi, @mkwatis mr. VINHAI is 100 % correct. |
hi, @mkwatis mr. VINHAI is 100 % correct. WBR, ANUCHOPRA.:) :) :) |
mates no need to change UPP, just try my post;) BR |
3100 pp... tick write pp.BR |
dear teefa thk's your pm for nokia 3120 was delicios :)) i had a same problem and tested works 100% regards man!!! keep goog work!!! salut! |
3100 spk problem ..solution pls |
