3120 help hi I have a 3120...flashing is ok not power on...I try to flash the phone 6.01 mcu+ppm...no local mode...not power on....any solution please....regards |
BR |
1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x017FFFFF,0001277E,Amd 29BDS064J Algorithm: u_amd.fia Algorithm Ok, MSID: 84AB2C81CD07EB299D79837DEE Decoded MSID: 8FA4BAE9-00CFA6A7-A8000000 Encoded FAID: A9D012A6-419BFA3B-91A0FE3E Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x0154FFFF Erased, Time: 00:44 Area3: 0x01680000-0x017EFFFF Erased, Time: 00:11 Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:39 Area1: 0x01550000-0x0167FFFF Erased, Time: 00:09 CNT Flashing Completed, Time: 00:03 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
please flash with all different versions of the software u have one of them should work it will show running nokia file server (after cnt flashing) then all will b ok even if after cnt extraction successful if phone not coming on then display problem best o luck :cool: |
I will try.... thanks for reply............regards |
thanks all for reply...I try all solution .. :mad: :mad: but it same...any solution please...regards |
Flash it separate first only MCU, then PPM, and at last CNT. It will works |
1. U try to full erase and flash it again with lastest FW, if not OK try to flash it with older FW ex: 5.02 (MCU+PPM+CNT must be the same version). 2. If not solve maybe hardware have problem, u must change UEM and Flash IC then flash again and use any RPL file to write UEM. B.R Vinh Hai |
Thanks all for reply...I problem solve....I make erase flash..with the desk 6.01 mcu+cnt 06.01.ucp_xb1.+5.91 ppm+good pm+full factory..problem solve....regards :D :D :D |
guys, can anyone share a good pm? why if I upload another PM, not the original one, UFS says 'Not found' in Provider line? |
Download PM RH-19_full_without_Imei from here http://www.restech.pl/upload/index.p...irectory=NOKIA B.R Vinh Hai |
The PM was not good... it was perfect! Big thanks! Interesting, how to remove IMEI from the PM? Just to find it and delete? Here is the way I put the phone to full life: 1. Flashed MCU 6.01 + CNT (6.01.ucp_xf1) ... with no UI Settings 2. Flashed PPM 06.01f (the same version as MCU & CNT, tried 5.91 and got Contact Service). Needed to press power button once. 3. UI Settings (All checkboxes) 4. Wrote PM. While writting got the following: Quote:
6. Checked info. Everything was OK there: Quote:
