Old 07-16-2005, 18:08   #1 (permalink)
kardelen gsm's Avatar
Member: 133173
Thanks Meter: 119
3120 help
hi
I have a 3120...flashing is ok not power on...I try to flash the phone 6.01 mcu+ppm...no local mode...not power on....any solution please....regards
Old 07-16-2005, 21:04   #2 (permalink)
jarniel's Avatar
Member: 149600
Thanks Meter: 9
Originally Posted by kardelen gsm
hi
flash it again with griffin...it will work 100%
Old 07-16-2005, 22:23   #3 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 134
hi
try flash with 6.01mcu + 5.91ppm
Old 07-17-2005, 17:14   #4 (permalink)
Member: 133173
Thanks Meter: 119
thanks for reply...I try...but it same....any solution please...regards
1st Boot Ok, DCT4, UPP: 1120
Fl0: 0x01000000-0x017FFFFF,0001277E,Amd 29BDS064J
Algorithm: u_amd.fia
Algorithm Ok, MSID: 84AB2C81CD07EB299D79837DEE
Decoded MSID: 8FA4BAE9-00CFA6A7-A8000000
Encoded FAID: A9D012A6-419BFA3B-91A0FE3E
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Area2: 0x01010000-0x0154FFFF Erased, Time: 00:44
Area3: 0x01680000-0x017EFFFF Erased, Time: 00:11
Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:39
Area1: 0x01550000-0x0167FFFF Erased, Time: 00:09
CNT Flashing Completed, Time: 00:03
Extracting Contents Package ...
Init Local Mode Failed
Contents Package Extracting Failed:
Process Failed, Repowering Mobile
Old 07-17-2005, 17:23   #5 (permalink)
gsmindia's Avatar
Member: 107636
Thanks Meter: 99
please flash with all different versions of the software u have one of them should work it will show running nokia file server (after cnt flashing) then all will b ok even if after cnt extraction successful if phone not coming on then display problem
best o luck
Old 07-17-2005, 17:27   #6 (permalink)
Member: 133173
Thanks Meter: 119
best o luck
I will try.... thanks for reply............regards
Old 07-17-2005, 20:19   #7 (permalink)
jarniel's Avatar
Member: 149600
Thanks Meter: 9
just flash it with a higher ver. after processing ok it will appear local mode then press the power manually for 5 sec. until it will detect to erase and write again. or after cnt flashing complte press the power to detect it again... just press the power every sec., coz i make this process phone successfully work... hope it will help you....
Old 07-19-2005, 14:24   #8 (permalink)
Member: 133173
Thanks Meter: 119
thanks all for reply...I try all solution .. but it same...any solution please...regards
Old 07-19-2005, 21:52   #9 (permalink)
Member: 162268
Flash it separate first only MCU, then PPM, and at last CNT.
It will works
Old 07-20-2005, 18:06   #10 (permalink)
VinhHai's Avatar
Member: 34310
Thanks Meter: 23
Hi kardelen,
1. U try to full erase and flash it again with lastest FW, if not OK try to flash it with older FW ex: 5.02 (MCU+PPM+CNT must be the same version).
2. If not solve maybe hardware have problem, u must change UEM and Flash IC then flash again and use any RPL file to write UEM.
B.R
Vinh Hai
Old 07-25-2005, 14:20   #11 (permalink)
Member: 133173
Thanks Meter: 119
Thanks all for reply...I problem solve....I make erase flash..with the desk 6.01 mcu+cnt 06.01.ucp_xb1.+5.91 ppm+good pm+full factory..problem solve....regards
Old 09-28-2005, 15:26   #12 (permalink)
Member: 104046
guys, can anyone share a good pm?
why if I upload another PM, not the original one, UFS says 'Not found' in Provider line?
Old 09-28-2005, 15:34   #13 (permalink)
VinhHai's Avatar
Member: 34310
Thanks Meter: 23
Hi,
Download PM RH-19_full_without_Imei from here
http://www.restech.pl/upload/index.p...irectory=NOKIA
B.R
Vinh Hai
Old 09-28-2005, 16:40   #14 (permalink)
Member: 104046
The PM was not good... it was perfect!
Big thanks! Interesting, how to remove IMEI from the PM? Just to find it and delete?
Here is the way I put the phone to full life:
1. Flashed MCU 6.01 + CNT (6.01.ucp_xf1) ... with no UI Settings
2. Flashed PPM 06.01f (the same version as MCU & CNT, tried 5.91 and got Contact Service). Needed to press power button once.
3. UI Settings (All checkboxes)
4. Wrote PM. While writting got the following:
Group Id:[158] Rec: 35 Len: 32723 .. Skipped
Warning : Too long record, can't handle
Group Id:[158] Rec: 36 Len: 31659 .. Skipped
Group Id:[158] Rec: 37 Len: 15002 .. Ok 126
Group Id:[158] Rec: 38 Len: 43411 .. Skipped
Group Id:[158] Rec: 39 Len: 175 .... Ok 2
Group Id:[158] Rec: 40 Len: 61699 .. Skipped
Group Id:[158] Rec: 41 Len: 203 .... Ok 2
Group Id:[158] Rec: 42 Len: 65516 .. Skipped
Group Id:[158] Rec: 43 Len: 221 .... Ok 2
Group Id:[158] Rec: 44 Len: 33350 .. Skipped
Group Id:[158] Rec: 45 Len: 230 .... Ok 3
Group Id:[158] Rec: 46 Len: 38961 .. Skipped
Group Id:[158] Rec: 47 Len: 227 .... Ok 3
Group Id:[158] Rec: 48 Len: 55588 .. Skipped
5. UI Settings again.
6. Checked info. Everything was OK there:
MCU Sw: V 06.01 18-03-05 RH-19 (c) Nokia.
PPM Sw: V 06.01 18-03-05 RH-19 (c) Nok F
Prd.Cd: 0508689
Bpr.Cd: 0507780
Pro.Sn: COA779323
HW : 0630
PCI :
UEM : 8
UPP : 4384
RFIC : 03122
DSP : N4.11
LCD : X4
IMEI : 355022-00-######-8 (hidden by me)
SLconf: 001-01-00000000000
SLprof: 000000000000000-2
SLvar : 00553550220039653700
SLaux : 00025555
Provider: Test Equipment
#pw+ 228 105 640 633 213 +1#
#pw+ 127 894 244 500 302 +2#
#pw+ 012 803 732 010 311 +3#
#pw+ 223 325 444 155 733 +4#
#pw+ 185 424 406 326 537 +5#
#pw+ 953 262 675 154 770 +6#
#pw+ 885 831 704 310 542 +7#
Thank you!
3120 help ChandruChiyyan Nokia Hardware & Hardware Repair 8 08-03-2009 22:19
Nokia 3120 help Rizwan ch08 Nokia Hardware & Hardware Repair 1 01-02-2008 10:23
3120 help .:SARCAR:. Nokia Hardware & Hardware Repair 9 03-07-2007 22:12
Page generated in 0.42245 seconds with 8 queries
