Old 02-22-2007, 19:11   #1 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,340
3120 help
friends I have a nokia 3120 which was software problem
then i decided to flash the phone with ufs , I flash mcu+ppm v.5.90 but same result . then did erase to id 01000000-01FFFFFF , but ufs give me the report that out of chip bounds
then I decided to edit id to 01000000-013FFFFF & did erase
now mcu+ppm flash complete but cnt failed
I also erase id 01000000-017FFFFF but same , ufs shows 1st boot ok
Please help me
Old 02-22-2007, 19:32   #2 (permalink)
Member: 249504
Thanks Meter: 2
from all of your speaking i understood that the phone is giving an error in cnt. please try with jaf.. if you cant get a positive result, i offer you to replace/block/rehot flash ic.
Old 02-23-2007, 21:37   #3 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 405
Please help me
just flash fone without cnt.... flash it with mcu+ppm.... all b fine
Old 02-24-2007, 01:51   #4 (permalink)
Member: 197538
Thanks Meter: 97
Erase address for 3100/3120/6100 is 01000000-017FFFFF
If local mode not ok than u cant extract CNT file bro ,,,, If flashing MCU and PPM ok and phone not power onn than check UEM reflow or rehot .... but first try to flash MCU and PPM and check if phone turning on or not ,,,?
What was the initial problem in the phone before u flashed ? 30secs off or restart ?
Please post history and log for further help
AK
Old 02-24-2007, 11:31   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,340
thank you friends for reply , the phone has network problem & also restart while doing manual network search
I also tried flash without cnt only mcu+ppm , flashing ok but cant enter in local mode, while erase id 01000000-017FFFFF I think all memories are erased
please guide me
thanks
Old 02-24-2007, 20:52   #6 (permalink)
Member: 275631
Thanks Meter: 405
reball or change cpu.... if dint wrk than change flash
Old 02-25-2007, 19:09   #7 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,340
today I flash the phone with erase file & it shows the folling error
Erasing : 0X011FC000 - 0X011FFFFF ...
Erasing Error : 10 , at : 0X011FC000-0X011FFFFF , 940206
Process Failed
I think it's a flash ic problem
Please guide me
Old 02-26-2007, 17:31   #8 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Process Failed
Please guide me
Try to reheat SDRAM and reflash it.If still change it and reflash.
Old 03-07-2007, 22:09   #9 (permalink)
Member: 356609
flash the phone without cnt using v6.01
Old 03-07-2007, 22:12   #10 (permalink)
Member: 356609
you don need to hot the phon that is only softwere solution can be applyd.
3120 help ChandruChiyyan Nokia Hardware & Hardware Repair 8 08-03-2009 22:19
Nokia 3120 help Rizwan ch08 Nokia Hardware & Hardware Repair 1 01-02-2008 10:23
3120 help kardelen gsm Nokia Hardware & Hardware Repair 13 09-28-2005 16:40
Page generated in 0.28674 seconds with 8 queries
