Old 10-07-2007, 05:48   #1 (permalink)
markrhi's Avatar
Member: 520956
Thanks Meter: 12
3120 network solution 75% ok
brother, 3100 network solution...just flash w/ latest version..then reball mjoulner and apply jumper in white filter...
Old 10-07-2007, 05:51   #2 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Will you upload pic for jumper ?
thanks in advance
Old 10-07-2007, 07:51   #3 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
upload here picture and share with us
Old 10-08-2007, 12:56   #4 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
yes it is a regular problem , so please post picture to let us know better and try your solution
Old 10-08-2007, 14:06   #5 (permalink)
Member: 17623
Thanks Meter: 79
he says only 75 % prolem solved .. means he is not sure for above ....
Old 10-08-2007, 14:20   #6 (permalink)
Member: 17623
Thanks Meter: 79
i give u 100% solution.
just reball UEM
ur problem will solved definitely
Old 10-08-2007, 14:25   #7 (permalink)
Member: 604839
Problem of network in these telephones always covered or in a rf processor or in uem or in cpu. Often simply no soldering.
Old 10-08-2007, 14:33   #8 (permalink)
**Nadeem**'s Avatar
Member: 562828
Thanks Meter: 13
i give u 100% solutoin.
Old 10-08-2007, 16:47   #9 (permalink)
Member: 321039
Thanks Meter: 15
its normally coz of rf filter as for as i have seen 80% get the problem in Rf filters
Old 10-08-2007, 17:16   #10 (permalink)
chinchik's Avatar
Member: 145494
Sonork: 100.111656
Thanks Meter: 18,407
network problem in 3100\3120\2112\3105\3125\6100\6610\7210 etc is 100% uem problem just reball this or may change it its work 1000% nothing else will do if it is software related then write pm to set then it work
wbr
sachin
The Following User Says Thank You to chinchik For This Useful Post:
Old 10-08-2007, 17:55   #11 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hi,
sacin is right but it is not possible to change um because customer dont want to pay money for um change. but it can possible by reball. best of luck my brother.
Nokia 3120 Network Problem ramdev_mobbile Nokia Hardware & Hardware Repair 3 07-13-2010 08:46
3100 3120 6100 Network solution gul551 Nokia Hardware & Hardware Repair 0 12-14-2009 19:07
nokia 3100 and 3120 network solution pradeep agrawal Nokia Hardware & Hardware Repair 34 02-21-2009 12:02
Nokia 3100,3120,3220 100% Network Solution.. amit123 Nokia Hardware & Hardware Repair 0 01-23-2008 20:39
2100 network solution %100 ok sevgigsm Nokia Hardware & Hardware Repair 1 04-06-2005 00:38
Page generated in 0.20497 seconds with 9 queries
