Old 02-11-2010, 23:30   #1 (permalink)
Member: 229823
Thanks Meter: 22
3120c test mode
I have recived a 3120c (rm364) that always shows TEST MODE. I've changed n2200, n2300, r2007, removed rezistor and capacitator near battery connector, but nothing changed.... Just test mode. I think phone was water damaged....can anyone help me pls???
The Following User Says Thank You to doublex_gsm For This Useful Post:
Old 02-12-2010, 00:03   #2 (permalink)
geosan1638's Avatar
Member: 5204
Thanks Meter: 35
the bsi line has only 2 components before it goes into AVILMA , R3400 and C3402. So, after removing these 2 components you still get Test mode just remove AVILMA(N2200) find the track that goes to the battery connector(bsi line) and check for impedance between BSI line and Gnd. If you find any the PCB was damaged by the liquid and the only way fix that is to put a few AMPS on that line and hope your impedance goes away.
Best of luck!
The Following User Says Thank You to geosan1638 For This Useful Post:
solutions can't local mode,test mode,normal mode after reflash in here uwenk98 Nokia Hardware & Hardware Repair 30 07-27-2013 12:27
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested /\/\A/\/| Nokia Hardware & Hardware Repair 14 07-11-2011 06:49
flash,local mode,test mode,normal mode big problem need help gsm_cdma_ufs Nokia Hardware & Hardware Repair 0 04-10-2009 11:50
1600 fleshing ok local mode/test mode ok but normal mode fail zargar322 Nokia Hardware & Hardware Repair 9 03-31-2008 17:22
Test mode, Local mode Normal mode royke Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-13-2002 12:33
Page generated in 0.26654 seconds with 8 queries
