Old 06-12-2006, 14:10   #1 (permalink)
Member: 263548
Thanks Meter: 24
3200 no network
Anyone pls advise !! i got 3200 with no network, s/w run it but still same...which ic should I change 1st? I have re**** PA n helgo but still same...
Old 06-12-2006, 14:44   #2 (permalink)
W4r10rD's Avatar
Member: 183043
Thanks Meter: 68
you have written new software, but did you write PM as well.If you did i suggest to replace the antenna switch and then the HAGAR.
Old 07-06-2006, 14:02   #3 (permalink)
BalfourCellular's Avatar
Member: 86981
Thanks Meter: 10
Remove The Duplexer Check For Cracks Below. A 3310 Duplexer Can Replace That One. Do Not Bridge The Duplexer. (work Properly Not Like A Fool) Also Remove The Pa And Clean The Pads Below And Refit Properly.
3200 no network uwenk98 Nokia Hardware & Hardware Repair 7 10-31-2008 17:43
3200 no network after flashing with good pm nizoudj Nokia Digital Core Technology 4 ( DCT-4 ) 1 07-04-2007 14:34
3200 no network yoya Nokia Hardware & Hardware Repair 6 07-06-2006 14:04
Nokia 3200 No Network (no signal) Brckela Nokia Hardware & Hardware Repair 7 03-17-2006 12:24
Page generated in 0.12354 seconds with 9 queries
