10-07-2004, 14:11 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | to remove 3200 PA is almost easy, you need : 1. hot air, seting air 3 and heater 5 2. a little of flux 3. tweezer or pincer. put a little of flux on pa and hoting it and take out. |
10-07-2004, 14:23 | #3 (permalink) |
Junior Member Join Date: Aug 2004
Member: 79200 Status: Offline Thanks Meter: 0 | 3200 Pa Thats what I ussualy do. (older phones) 3200 however seems like liquid solder or ? doesn't melt (so being frustrated today - used force - bad idea for any mobile repair) any advice... NiQ |
10-08-2004, 07:41 | #5 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | Before removing PA or any IC, when u are heating component (of course using flux) at first try to little push forward BGA/LGA component and check if it is "sliding". If Yes, now u can easilly put it up, without destroying solder pads... Regards. |
nokia 3120c pa and 3110c pa same or not | alammov | Nokia Hardware & Hardware Repair | 2 | 01-07-2010 10:28 |
myx5-2v PA or PA jumper needed | GOODNESS | Sagem Hardware Repair Area | 0 | 11-01-2008 00:18 |
nokia 3200 pa compatable? | Byte | Nokia Hardware & Hardware Repair | 0 | 09-15-2005 15:02 |
to>Jero 3310 plastic PA metal PA | hs_ | Nokia Hardware & Hardware Repair | 4 | 02-06-2003 23:35 |
can i change 5210 PA with PA for 8210 ? | bengong | Nokia Hardware & Hardware Repair | 4 | 10-22-2002 18:39 |
