Old 02-17-2004, 21:27   #1 (permalink)
The Racer's Avatar
Member: 20490
Thanks Meter: 3
Is it possible 8390->8310?
Is it possible? A solution for 3390-> is allready on the forum.
Old 02-20-2004, 10:46   #2 (permalink)
Member: 7545
it might be possible... you have service manual for 8390?
Old 02-20-2004, 11:46   #3 (permalink)
The Racer's Avatar
Member: 20490
Thanks Meter: 3
No i dont have SM for 8390?
Anyone test it?
Old 04-02-2004, 12:37   #4 (permalink)
blue1's Avatar
Member: 60613
maybe...do u have both phones to see if there any difference?
Old 04-04-2004, 15:20   #5 (permalink)
Member: 7586
Thanks Meter: 11
im interested in changing 8390 to 8310 too.
i found on forum picture for changing 3590 to 3510i , and link (which is not working) for changing 6590 to 6510.
8310 and 6510 is same so i think solution for changing 6590 to 6510 works also on 8390.
i compare 8310 a 8390 boards and the differences are in PA, AS, FDK (VCO)
does solution for 3590 works also on 8390 ?
so if i change VCO and 3 filters and flash it with 8310 sw phone will work on 900/1800 ?
b.r.
Pali
Old 04-04-2004, 15:26   #6 (permalink)
kcgckc2002's Avatar
Member: 42539
Thanks Meter: 182
here:
br
Old 04-05-2004, 18:18   #7 (permalink)
kcgckc2002's Avatar
Member: 42539
Thanks Meter: 182
vco to use, of course from 8210 or 8850
Old 04-14-2004, 16:26   #8 (permalink)
Member: 7586
Thanks Meter: 11
vco from 8210 or 8850 is bigger , cant fit it there .
any idea?
Pali
Old 04-14-2004, 20:36   #9 (permalink)
Member: 7586
Thanks Meter: 11
rebuild done .
phone is now 8310 and has network. can make calls .
not sure it it is 900 or 1800 or both but working for now.
thanx for post.
what about 8290 to 8210 is it possible ? i have here new board for 8290 .
Pali
Old 04-14-2004, 20:53   #10 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
gr8
whats for 3590 to 3510
Old 04-16-2004, 10:29   #11 (permalink)
The Racer's Avatar
Member: 20490
Thanks Meter: 3
for me it doesnt work maybe bad vco
Originally Posted by pali
rebuild done .
thanx for post.
Pali
SMS Animated Indicator-Is it possible to correct it? GoLL@B x4x, x5x Flashpatching 0 11-12-2005 11:39
Is it possible to flash 8130 v 106+ , please post just if you did it already gsmnice LG 8 04-13-2005 01:17
No RUSSIAN? flash for K500i! is it possible that it might support K700 flash file?? AE177 Griffin 0 10-22-2004 00:02
T610 is it possible to unlock or does it have TP ? Gsmhq Twisterflasher 10 08-21-2004 16:15
Is it possible to lock phone again, as it was then I bought it? jonis2002 x1x to x45/x50 4 09-27-2002 21:17
Page generated in 0.21284 seconds with 10 queries
