08-13-2003, 17:59 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | 3210 buzzer problem i have 3210 with damaged buzzer pad + . on 3210 there are 4 pads on PCB. x -??? 0 - to UI pin 6 0-gnd 0 - gnd where to connect this damaged? b.r. Pali |
08-13-2003, 19:33 | #2 (permalink) |
Freak Poster Join Date: Mar 2003 Location: MNE Age: 43
Member: 23848 Status: Offline Thanks Meter: 13 | The buzzer circuit is so simple that you can fix it in few minutes!! The + pin is connected to a hole near the LCD contacts:when you turn the board with the buzzer facing up there are 3 vertical holes just by the last LCD contact on the right.The + pin from the buzzer is connected to the MIDDLE HOLE near the LCD pins. If you got me right and all other is good the problem is solved!! I`m sorry that I don`t have a picture,but I hope this helped you. Salut!!!! |
Sony J70 buzzer problem | Porter | Sony Ericsson Hardware Repair | 9 | 03-16-2005 11:36 |
3210 Buzzer .................... | fdupoi | Nokia Hardware & Hardware Repair | 7 | 08-10-2003 07:54 |
R200 buzzer problem | tereshuk | Samsung Hardware Repair | 1 | 05-27-2003 13:11 |
T 190 buzzer problem | Moosani | Motorola ODM | 1 | 03-06-2003 16:21 |
3210 Buzzer Problem! | aspog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-05-2001 17:06 |
