04-03-2003, 09:24 | #1 (permalink) |
Freak Poster Join Date: Oct 2001 Location: romania
Member: 6719 Status: Offline Thanks Meter: 1 | 3210 charging problem again The phone show charging but not charging, on +pin whithout batery i have 1.3 v not 2.4 i change n100,n101,v114,r137,c122 i have checked and resolder r127 to gnd, line from 127 to 125 is ok, on c100 i have 4v, i have change v101,c109 c110,c113,c115,r102, and not solve my problem. |
04-03-2003, 12:13 | #2 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Croatia Age: 49
Member: 14004 Status: Offline Thanks Meter: 6 | Did you tried to resolder X101? I had 3 phones with the same problems, and i checked everything, and still not charging. All the time i was checking X101 with multimeter - all OK. Then i lifted X101 from board and resoldered it again - phone charging normaly. Problem is that X101 has 3 contacts conected to GND and one to R127 - this one can cause not charging. |
05-15-2003, 04:49 | #5 (permalink) |
Junior Member Join Date: May 2002 Location: manila
Member: 11508 Status: Offline Thanks Meter: 0 | Hello! In my case, the contact metal pad of R127 nearer X101+ had been removed...do I jumper tap directly to X101+ or to R125? Is there a closer tap point? Thanks, Sandy |
05-16-2003, 03:20 | #6 (permalink) |
Member: 11508 Status: Offline Thanks Meter: 0 | Hello again! I solved my problem...I jumped-tapped from R127 to R125 and C155 and now phone has power on and starts charging even better than before. (It helps if you do a little research through the older posts.) Ciao, Sandy |
Nokia 3210 charging problem | YamahaR1 | Nokia Hardware & Hardware Repair | 17 | 08-17-2012 14:36 |
3210 charging problem | j_h_u_n | Nokia Hardware & Hardware Repair | 4 | 08-10-2002 04:12 |
3310, 3210 charging problem | patrynio | Nokia Hardware & Hardware Repair | 2 | 07-15-2002 00:41 |
6210 & 3210 charging problem | tagoy | Nokia Hardware & Hardware Repair | 3 | 03-07-2002 18:45 |
3210 charging problem???? | sawa | Nokia Hardware & Hardware Repair | 1 | 12-28-2001 09:46 |
