11-17-2001, 11:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Netherlands
Member: 2100 Status: Offline Thanks Meter: 40 | 3210 not charging <br />GsMen |
11-17-2001, 18:32 | #3 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Russia
Member: 5850 Status: Offline Thanks Meter: 0 | Hi!<br />What is the symtoms when you plug in charger?<br />1. Nothing<br />2. Beep and "not charging"<br />3. Charging bar indicates, but battery isn't charging |
11-17-2001, 21:22 | #5 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Italy
Member: 7301 Status: Offline Thanks Meter: 0 | Hi All! I think you can check with wintesla the "ADC Readings" ... If battery temperature is -273°C the fault is on the NTC behind the battery contacts: resolder the negative battery contacts and all will be ok! <img src="smile.gif" border="0"> |
11-30-2001, 23:45 | #8 (permalink) |
Junior Member Join Date: Nov 2001 Location: Hungary
Member: 7692 Status: Offline Thanks Meter: 0 | There is a fuse on the PCB, keyboard side, left bottom, small white SMD thing... if this is broken, can lead to no charging. Test it with multimeter, if broken, use some thin wire :-) |
12-02-2001, 14:29 | #9 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | nothing happend whenu plug the charge = <br />1-change the fuse resistance which is mark (K)<br />2-check pcb connection legs<br />not charging masseage =<br />1-the big resistance r220 beside the eeprom <br />2-the third capacirtor beside the fuse<br />3-the small capacitor between the batt.conector<br />thanx welcom please nnurte message me please i need to discusse something with u <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="mad.gif" border="0"> |
3210 not charging displayed | Vicky | Nokia Hardware & Hardware Repair | 42 | 11-03-2008 11:20 |
3210 not charging with car-charge | fiZ | Nokia Hardware & Hardware Repair | 4 | 10-18-2002 14:52 |
3210 not charging | platte | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 22 | 02-06-2002 22:40 |
3210 not charging! | aspog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 07-06-2001 08:45 |
3210 not charging | ambot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-06-2001 21:41 |
