05-05-2002, 23:34 | #3 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | thanx for reply thanx for reply ..... but i already rehotted battery socket and capacitors near it, also i changed all capacitors near charging socket, no result,! could u exactly tell me where i should check ? thanks |
05-06-2002, 23:01 | #5 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Here Age: 44
Member: 7676 Status: Offline Thanks Meter: 4 | ok man if resolder the battary conntacter and the capistar then check the capistar near the charge ic then try to rehot the charge ic , if not work then change it |
05-08-2002, 05:59 | #7 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | hi friends, To solve this you should go step by step: 1- If the phone charge some times and others no, verify mecanical problems ( charger, charge connectors) 2- If the phone does'nt accept charge then, try to load 3210 service manual and i will explain to you. gooooooooofd luck |
05-13-2002, 19:52 | #10 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | simply change the chrging gruops of capictors concern the charching in the bottomos side the side contain the cpu so this gruop it s at the left botom side ofthe board up to the charging fuze ... thanksssssss |
05-13-2002, 22:22 | #11 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | thanx raheeb I done all in bottom of the board and replace capacitors but now my phone chargeing in power off mode, blicks battery and in power on mode: says: Not Charging, I replaced cap. between batter contacts, still no result please help me |
05-13-2002, 22:55 | #12 (permalink) |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | @ ARC-- partner here are the results tested on three phones--- == kindly resold the battert socket+ there are two capacitors between the socket - try to resold them properly== and reflow charging ic near the an****a - if all above not work than change the charging ic.... works 100% for me -- i hope the abovementioned give u some help .... best regards gohar |
help 3210 "NOt Charging" | bruce77 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 02-10-2005 17:01 |
3210 "not charging" | ataman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 10-24-2004 11:29 |
power on 3210 "not charging" | vidas | Nokia Hardware & Hardware Repair | 0 | 05-08-2002 20:57 |
6210 "Not Charging" Displayed. | N/East Unlocker | Nokia Hardware & Hardware Repair | 5 | 10-16-2001 18:03 |
Nokia 7110 "not charging" | Sekoel | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-11-2001 12:01 |
