Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 03-14-2003, 19:39   #1 (permalink)
Member: 17647
3210 ringer prob
hi everyone, i have a 3210 that wont ring , i've changed the ringer but still no joy, i've checked that ringing is turned on in the menu but I can only get keypad sounds but no ringtone sounds. help please !
Old 03-15-2003, 15:01   #2 (permalink)
Member: 19142
check connect ringer with driver on pcb with service manual
Old 03-15-2003, 15:02   #3 (permalink)
Member: 19142
maybe any track is broken
Old 03-15-2003, 15:31   #4 (permalink)
Member: 17647
thanks m8 , any ideas which pin on pcb is connected to the ringer?
Old 03-15-2003, 16:22   #5 (permalink)
Member: 17647
i've checked all connections back from ringer(B400) to N400 chip , all connections are perfect, I've tested ringer on another pcb & that's perfect too, any ideas please.
Old 03-16-2003, 17:21   #6 (permalink)
Crazy Poster
Member: 13566
maybe it's because of bad flash. at first try to do factory reset. good luck.
Old 03-17-2003, 09:07   #7 (permalink)
Member: 19142
when all track is ok try change N400 chip this is driver buzzer, led, vibra
once i damage this chip when i try resold this and i set too high temperature
Old 03-18-2003, 15:33   #8 (permalink)
GazI's Avatar
Member: 20566
hi try this to conect
Old 03-19-2003, 13:30   #9 (permalink)
Member: 17647
Brilliant. Thanks very much, works perfectly.
Old 03-19-2003, 13:46   #10 (permalink)
Member: 19142
pin 5 in service manuals go in to ground.My service manuals is wrong?
Old 03-20-2003, 11:06   #11 (permalink)
Springer's Avatar
Member: 15909
No, service manuals is not wrong, ringer connect to pin6.
Old 03-20-2003, 11:17   #12 (permalink)
Member: 17647
the solution by g-force worked perfectly. thanks everyone for your help.thanks again g-force.
3210 ringer not working but keypad tones do??? bluelights Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 05-10-2010 06:47
Nokia 3210 Ringer udayangacnu Nokia Hardware & Hardware-Repair Area 0 07-02-2009 06:44
3210 ringer problem..... RAHUL12345 Nokia Hardware & Hardware-Repair Area 5 07-14-2004 16:03
C45 firmware 38 ringer probs ?? Enigma214 x1x to x45/x50 1 06-06-2003 00:56
8210 ringer prob Cyber_killer Nokia Hardware & Hardware-Repair Area 0 08-05-2002 00:29
Page generated in 0.31254 seconds with 11 queries
