05-24-2004, 16:39 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: India (Mumbai) Age: 43
Member: 59915 Status: Offline Thanks Meter: 4 | 3210 ringer problem..... I have 3210 with ringer problem. The pads of ringer are broken. Tried to jump wire to user interface 5th pin on right side and other near speaker pad...... I have done jumping on 5th pin...... but the problem is that i cant do jumper near speaker pad,,it is not catching solder. Plz help thanx |
05-27-2004, 04:27 | #3 (permalink) |
Junior Member Join Date: Jan 2004 Location: Pangasinan, Philippines Age: 52
Member: 50477 Status: Offline Thanks Meter: 0 | one more thing, the correct pin from UI IC to be connected to the negative side of the buzzer should be pin 6 and not pin 5. Last edited by lito_bee; 05-27-2004 at 04:46. |
07-14-2004, 16:03 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | 3210 ringer problem +ve is coming direct from battery. 1) Check continuity from battry to ringer pad 1. 2) Check continuity from ringer pad 2 to UI IC leg No. 6. Nokia has common problem for this. 3) Check battery volt at UI leg 1. 4) Check 2.8V at UI leg 2. 5) Check 2.8V at UI leg 5 when 'Ringer Enable'. |
3210 ringer not working but keypad tones do??? | bluelights | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 05-10-2010 06:47 |
Nokia 3210 Ringer | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-02-2009 06:44 |
d780 flashing problem...after flashing ringer problem | gsm st | SWIFT Platform | 2 | 03-22-2009 22:29 |
3210 ringer prob | golden | Nokia Hardware & Hardware Repair | 11 | 03-20-2003 12:17 |
8210 Ringer problem | gsnbhagawan | Nokia Hardware & Hardware Repair | 0 | 06-20-2002 14:25 |
