3210 says "no charging" in display hi friends, i have a 3210 and it's say no charging i change bateries, x100, charger ic, v100,r103, r104, r131,L104,f101(shorted),c103,c114, try change ccont , and nothing, the same problem, and look all resistors about lines 62, 60(n100,ccont) and line 1,16, 5, 12 about charger ic (n101) and all are perfect, whats the problem |
try to replace the NTC resister between the battery contact and resolde it |
1 Attachment(s) Take a look :) :) :) |
maybe, voltage is over or below required!! |
@xpressmoviles, First reflow the black resistor(thermal resisitor) btn the batt pad, if it doesnt work connect a wire from that resistor to nearest "lower" batt pad and ur fone will start charging ! ;) WBR, BANTUGBRO. Quote:
bohosh / u r right ,'' not charging'' can solve by resold batt termnals /(importent'''''''note) (-v )and (v+) batrey termnal is must conacted 4 side soldering. regards gondal :) |
