Old 09-27-2004, 09:27   #1 (permalink)
Member: 76269
3210 says "no charging" in display
hi friends, i have a 3210 and it's say no charging
i change bateries, x100, charger ic, v100,r103, r104, r131,L104,f101(shorted),c103,c114, try change ccont , and nothing, the same problem, and look all resistors about lines 62, 60(n100,ccont) and line 1,16, 5, 12 about charger ic (n101) and all are perfect,
whats the problem
Old 09-27-2004, 18:53   #2 (permalink)
Cat10's Avatar
Member: 42123
Thanks Meter: 2
try to replace the NTC resister between the battery contact and resolde it
Old 09-28-2004, 08:21   #3 (permalink)
Bohosh's Avatar
Member: 14741
Thanks Meter: 119
Take a look
Old 09-30-2004, 16:56   #4 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
maybe, voltage is over or below required!!
Old 10-08-2004, 18:37   #5 (permalink)
BANTUGBRO's Avatar
Member: 43363
Thanks Meter: 2
@xpressmoviles,
First reflow the black resistor(thermal resisitor) btn the batt pad, if it doesnt work connect a wire from that resistor to nearest "lower" batt pad and ur fone will start charging !
WBR,
BANTUGBRO.
whats the problem
Old 10-24-2004, 11:20   #6 (permalink)
nobal1976's Avatar
Member: 71190
Sonork: 100.1580485
Thanks Meter: 87
bohosh / u r right ,'' not charging'' can solve by resold batt termnals /(importent'''''''note) (-v )and (v+) batrey termnal is must conacted 4 side soldering.
regards
gondal
V8 says "no battery when charging" The Repair Shop Motorola Hardware Repair 7 07-12-2008 20:56
nokia 2100 display "no charging" ??? eng.hamdow Nokia Hardware & Hardware Repair 2 04-27-2005 19:29
nokia 3200 camera "no charging" eng.hamdow Nokia Digital Core Technology 4 ( DCT-4 ) 3 10-30-2004 07:47
how to solve "no charging" problem after using ccs erase on 3650? Alinus Griffin 0 02-17-2004 04:06
Nokia 3210 "No Charging" HELP! mastergsm Nokia Hardware & Hardware Repair 6 02-06-2002 07:06
Page generated in 0.17710 seconds with 10 queries
