07-05-2001, 13:27 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Philippines Age: 47
Member: 4873 Status: Offline Thanks Meter: 5 | 3210 short stanby/use time... has anyone has a solution for this? thanks in advance |
07-13-2001, 01:44 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | i'm not sure about this but you can maybe check the charging control IC. I am sharing this from experience of charging control IC problem from 6150 wherein the charging takes sooo long and the phone self discharges. Just try leaving the phone off with bat.. check it overnyt and see if the bat is completely discharged the next morning... if it is then that it. |
07-13-2001, 07:24 | #3 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Tuzla, Bosnia and Herzegovina
Member: 3061 Status: Offline Thanks Meter: 0 | Sometimes the problem might be PA modules. CHeck them, remove their inductors ( check schematics to find out where are they) and then switch on phone and leave it to see wether this is the problem ( or if you dont know where inductors are, just remove both modules ). If your phone does not discharge in 5 hours then te PA modules are faulty and replace them!!! Best regards.... |
Short checking using power supply | irfan_gsm | Nokia Hardware & Hardware Repair | 3 | 02-26-2010 12:30 |
v360v uses a new battery in a short time | chris2007 | Motorola Hardware Repair | 2 | 08-31-2007 02:07 |
v360v uses a new battery in a short time | chris2007 | Motorola Hardware Repair | 0 | 08-29-2007 13:20 |
Nokia 6670 low stanby time | madve | WD2 & APE (Symbian Phones) | 3 | 04-04-2005 13:21 |
T180 - very short stan-by time. | jacck | Motorola Old Legacy (EMMI) | 0 | 03-17-2003 09:45 |
