05-24-2004, 16:32 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: India (Mumbai) Age: 43
Member: 59915 Status: Offline Thanks Meter: 4 | 3210 strange problem????? I have come across strange 3210 problem. Charging indicator goes very very slow......During charging session if i try to ON the phone it doesnt gets ON. But when i remove the battery and insert battery again then phone switches ON... Replaced B100 but no solution Plz help me........... Thanx |
05-27-2004, 03:45 | #3 (permalink) |
Junior Member Join Date: Jan 2004 Location: Pangasinan, Philippines Age: 52
Member: 50477 Status: Offline Thanks Meter: 0 | rahul; sometimes that problem is caused by a stuck switch. you can check the switch with a VOM tester. there should be no continuity between the terminals if the switch is not pressed. if there is continuity, then the switch is stuck. you can carefully disassemble it, then have it cleaned with a brush and a little alcohol. |
3210 strange charging problem | patrynio | Nokia Hardware & Hardware Repair | 0 | 08-30-2002 17:30 |
3210 strange problem shows C/S | patric | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-30-2002 13:24 |
strange problem 3210 | JeckeL | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-08-2001 12:44 |
strange problem 3210 | JeckeL | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-04-2001 10:48 |
Strange problem with 3210 | bobik | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-27-2001 18:41 |
