02-08-2006, 11:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 219831 Status: Offline Thanks Meter: 104 | 3220 *,0,# clr, key not work 3220 key *,0,# & clear not work there r z2400 emi filter ic sightly crack from corner there r conection of col4 need ic's input pin and output pin's diagram with this diagram i conect col4 input to output thnx |
02-09-2006, 09:15 | #3 (permalink) | |
Member: 219831 Status: Offline Thanks Meter: 104 | Quote:
there r must be replace EMI filter ic but without change ic how can i do co4 i/p to o/p conection posible???????????????? thnx | |
02-15-2006, 09:40 | #5 (permalink) | |
check row colon continuty vertical,centre point ( or check continuty with ok pcb then compare ) horizental,outside circle point no need to change keypad ic...... B R Amit Tank | |
1200 menu---*---0--#--9 keys not working | kcs_reddy | Nokia Hardware & Hardware Repair | 8 | 01-15-2009 08:50 |
k500I key 7,8,9,*,0,# and joystick not working | rajput_jitendra | Sony Ericsson | 2 | 09-20-2008 20:40 |
6600 *,#,C keys not working | khalidsain | Nokia Hardware & Hardware Repair | 9 | 09-30-2007 04:42 |
3220 *,0,# clr, key not work | Amit Tank | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 02-08-2006 10:34 |
6600 *,#,c keys not working | 47eleven-t | Nokia Hardware & Hardware Repair | 5 | 01-18-2005 17:29 |
