06-04-2005, 11:01 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | I don't understand what do you talking about, but I think you flash the phone with griffin and can't extract CNT files, if that is your problem, I think yes it can even griffin giving message " fail" but CNT exist on your phone... |
06-04-2005, 11:29 | #3 (permalink) |
Freak Poster Join Date: Jun 2004 Location: mars Age: 45
Member: 69445 Status: Offline Thanks Meter: 12 | im using twister, griffin and phoenix black box it shows cannot xtract files the phone is dead. i think the phone must finish extracting files so that it would turn on . just lioke 6610, any similar solution to finish extrcting this file |
06-04-2005, 11:42 | #4 (permalink) | |
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
06-04-2005, 11:46 | #5 (permalink) |
Member: 69445 Status: Offline Thanks Meter: 12 | i already flash the mcu and ppm area. i also removed the content file it flash mcu and ppm perfectly still no power . my *******r said that they tried to download games using gprs and after that it turned off and the phone is totaly dead. any hard ware solution . tnx |
06-04-2005, 20:10 | #6 (permalink) |
No Life Poster Join Date: Jan 2005 Location: india Age: 49
Member: 107636 Status: Offline Thanks Meter: 100 | hi most of the times this same problems are solved by flashing with all the possible versions of the software flash with each and every version of 6610 software on your hard disk one should definately click |
06-05-2005, 16:15 | #7 (permalink) | |
Freak Poster Join Date: Jul 2003
Member: 34310 Status: Offline Thanks Meter: 23 | @ gsmindia Quote:
I often get same ur problem and all of my phone will be OK now after I flash them again. What version of SW (DCTX) and FW did u have used to flash it? B.R Vinh Hai | |
06-05-2005, 22:45 | #8 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Russia, Yaroslavl Age: 43
Member: 46415 Status: Offline Thanks Meter: 16 | 2 MARKIE41: does the phone have mechanical or liquid damages? reball upp, uem and flash, also check for liquid paths or broken lines under ICs. if won't help, then replace uem and (or) upp. by the way, did you check bsi circuit? the problem you must solve is set the phone to local mode. |
06-05-2005, 22:55 | #9 (permalink) | |
Freak Poster Join Date: May 2002 Location: dubai
Member: 11945 Status: Offline Thanks Meter: 76 | Quote:
good luck. | |
11-08-2005, 15:10 | #13 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | Quote:
how can i extract files from a cnt firmware file? | UnlockerPT | Nokia Base Band 5 ( BB-5 ) | 0 | 02-04-2009 00:50 |
can not flash files eprom E61 | phung hung | Infinity-Box | 5 | 03-12-2008 17:50 |
Can not download files??? | sallu | Smart-Clip | 7 | 10-19-2007 15:19 |
Again Server Problem! Can Not Download Files! | KUBAT1 | MT-BOX | 2 | 05-23-2007 15:05 |
6800 can not extract files | aboud | Nokia Hardware & Hardware Repair | 0 | 06-06-2005 02:26 |
