Old 03-26-2006, 13:33   #1 (permalink)
Member: 229061
Thanks Meter: 3
6600 flashing error now 6600 dead
1st Boot Ok, WD2, UPP: 1081
Fl0: 0x00000000-0x007FFFFF,0001277E,Amd 29BDS064J
Fl1: 0x02000000-0x027FFFFF,0001277E,Amd 29BDS064J
Fl2: 0x04000000-0x047FFFFF,27020111,
Fl3: 0x06000000-0x067FFFFF,0111FFFF,
Algorithm: w3_amd.fia, w3_cbusb.fia
Algorithm Ok, MSID: 848B57841628E154AA318B0EDA
Decoded MSID: 3E4EBAF7-005669AF-A8000000
Encoded FAID: 4748FA15-6E7A5FAA-8D54270A
Cbus Boot Error: 9
Error Data1:
00000000: 00 96 84 8B 57 84 16 28 E1 54 AA 31 8B 0E DA 54 ....W..(.T.1...T
00000010: 27 02 27 11 01 04 01 00 7E 27 02 27 11 01 06 01 '.'.....~'.'....
00000020: 00 7E 27 02 27 11 01 FF FF FF FF FF FF FF FF FF .~'.'...........
00000030: FF FF FF FF FF FF FF 77 00 00 00 00 00 00 00 00 .......w........
Error Data2:
00000000: A3 72 72 7E 27 02 27 11 01 02 01 00 7E 27 02 27 .rr~'.'.....~'.'
00000010: 11 01 04 01 00 7E 27 02 27 11 01 06 01 00 7E 27 .....~'.'.....~'
00000020: 02 27 11 01 FF FF FF FF FF FF FF FF FF FF FF FF .'..............
00000030: FF FF FF FF 77 C3 72 00 00 00 00 00 00 00 00 00 ....w.r.........
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
Old 03-26-2006, 14:03   #2 (permalink)
bingo_888's Avatar
Member: 234955
Thanks Meter: 19
hi,
uncheck bluetooth then flash again, post result...
The Following User Says Thank You to bingo_888 For This Useful Post:
Old 03-26-2006, 14:15   #3 (permalink)
Member: 38922
Thanks Meter: 35
after this, if still same Problem, resold UPP and Flash and try to update again..
GreetZ
Old 03-26-2006, 15:01   #4 (permalink)
Member: 229061
Thanks Meter: 3
I uncheck it BT but still have same problem
Fl0: 0x00000000-0xFFFFFFFF,0001277E,Amd
Fl1: 0x02000000-0x01FFFFFF,0001277E,Amd
Fl2: 0x04000000-0x03FFFFFF,0001277E,Amd
Fl3: 0x06000000-0x05FFFFFF,0001277E,Amd
Cbus Boot Error: 9
Error Data1:
00000020: 00 7E 27 02 27 11 01 C6 00 00 EA 75 01 00 EA 78 .~'.'......u...x
00000030: 01 00 EA 7B 01 00 EA 8E 00 00 00 00 00 00 00 00 ...{............
Error Data2:
00000020: 02 27 11 01 C6 00 00 EA 75 01 00 EA 78 01 00 EA .'......u...x...
00000030: 7B 01 00 EA 8E C3 72 F3 B7 07 F6 06 D6 82 95 11 {.....r.........
Old 03-26-2006, 18:40   #5 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
reball flash ic
[email protected]
Old 03-27-2006, 02:28   #6 (permalink)
Member: 183971
check the ic flash
F12
F13
Old 03-27-2006, 21:14   #7 (permalink)
Member: 238890
hello guys.. i got the same problem..
what flash ic u think is faulty ?
dead after flashing,..
1st Boot Ok, WD2, UPP: 0082
Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT
Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT
Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT
Fl3: 0x06000000-0x067FFFFF,0001267E,Amd 29BDS643HT
Algorithm: w2_amd.fia, w2_cbusb.fia
Algorithm Ok, MSID: 84075FDC277DBED8495A3A81F8
Decoded MSID: 3E4EBAF7-000B5036-A9000000
Encoded FAID: 7ACC1452-5E23CB7B-8D1D3D55
Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
Area2: 0x00010000-0x007FFFFF Erased, Time: 01:11
Area3: 0x04000000-0x046FFFFF Erased, Time: 01:05
Area4: 0x06000000-0x066FFFFF Erased, Time: 01:07
Area5: 0x047C0000-0x047EFFFF Erased, Time: 00:01
BT MCM (21) Image Found: 0x0002DD94
BT MCM Registering Done
MCU Flashing Completed, Time: 04:34
Erasing: 0x00000000-0x0000FFFF ...
Erasing Error: 10, at: 0x00000000-0x0000FFFF, 940108, Time: 00:00
Old 03-28-2006, 11:42   #8 (permalink)
bingo_888's Avatar
Member: 234955
Thanks Meter: 19
hi,
this is not flash IC problem. 80% sram problem, reheat or replace sram...
Old 03-28-2006, 14:39   #9 (permalink)
Member: 247252
removal of sram
[quote=bingo_888]hi,
this is not flash IC problem. 80% sram problem, reheat or replace sram...[
/quote]pls tell me how to replace sram.is there any paste r liquid to remove the moulding over sram?
Old 03-28-2006, 14:58   #10 (permalink)
bingo_888's Avatar
Member: 234955
Thanks Meter: 19
[quote=kichans76]
Originally Posted by bingo_888
hi,
hi,
what do you mean moulding?
you can use hotair of course
Old 03-28-2006, 15:15   #11 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
Reheat flash IC's and reflash the phone or change bluetooth module and refullflash it.
Old 03-28-2006, 18:10   #12 (permalink)
Member: 229061
Thanks Meter: 3
I try to flash only mcu and then pm 100% ok and then rebooting mobile but same nothing
Old 03-29-2006, 14:39   #13 (permalink)
Shah87n's Avatar
Member: 234396
Thanks Meter: 9
Hello aoa good after noon
sir I have a problem in 3100 the r blinking, not flash by grifin and ufs please help me my id
[email protected]
Old 03-29-2006, 14:42   #14 (permalink)
Shah87n's Avatar
Member: 234396
Thanks Meter: 9
post me ur problem
@ [email protected]
I try to solve ur problem
Insh*****
Old 03-29-2006, 14:44   #15 (permalink)
Shah87n's Avatar
Member: 234396
Thanks Meter: 9
I have all hardwere solution picture
6600 flashing , Error[BDBDADAD] usernome Griffin 18 03-22-2005 11:37
6600 flash error help. ^PAX UFS2 + UFS3-Tornadoflasher 5 03-12-2005 13:28
try to flash 6230 now its dead benie UFS2 + UFS3-Tornadoflasher 11 02-23-2005 11:59
6600 Flashing Error! heiichi UFS2 + UFS3-Tornadoflasher 9 01-17-2005 16:40
Flashing R220 - now it's dead Kiril_8 VLSI, Conexant, Skyworks and Old Models 10 12-30-2004 19:21
Page generated in 0.21959 seconds with 9 queries
