Old 02-15-2008, 09:51   #1 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
3220 insert sim
i have n3220 with insert sim , set works fine before but there was no network i had changed pa , antina and some filters but still no network after this process i had reheated uem and cpu and now it shows insert sim
i had changed sim ic but still same ..
Any one plz help its very urgent
Old 02-15-2008, 10:03   #2 (permalink)
asimbutt's Avatar
Member: 394146
Thanks Meter: 56
reball the UEM .......
Old 02-15-2008, 10:07   #3 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Just try with new SIM ic if same reball the UEM.
Old 02-15-2008, 10:11   #4 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
can u plz tell its uem fault or cpu
Old 02-15-2008, 13:58   #5 (permalink)
mobilelink's Avatar
Member: 318277
Thanks Meter: 92
Bro ..reball UEM .post results
Cheers
Old 02-15-2008, 15:28   #6 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
salam
dear remove sim ic and make jumper then reply
if not work them nayb uem PROBLEM
CHECK THIS IMAGE
Old 02-15-2008, 16:11   #7 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
Originally Posted by ansari123 View Post
salam
CHECK THIS IMAGE
i had don this procedure before but stil same bro.....
The Following User Says Thank You to aryan_ For This Useful Post:
Old 02-15-2008, 17:44   #8 (permalink)
Member: 455842
Thanks Meter: 97
re ball uem mate .................................insert sim gone
Old 02-15-2008, 18:30   #9 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
i had reballed uem but insert sim bro
Old 02-15-2008, 18:42   #10 (permalink)
Member: 248086
Thanks Meter: 22
yes i agree just reball the uem if the same try to replace it
Old 02-15-2008, 18:59   #11 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
first of check the tracks, if the traks r ok then change the sim ic
if still giving the problem, then reflow UEM ok?
Best of luck
Adil
Old 02-15-2008, 19:48   #12 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
if u hav reballed uem & problem remains same it means out of 3 connections some tracks dont make correct path with uem (u can get vsim from capacitor) so,if it is so then bro u may have to take jumpers from uem to sim points rest will be ok. best of luck
Old 11-15-2009, 19:13   #13 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
i have a 6020 with insert sim i changed the emi filter and still the same.i did as you said that if after you change emi filter still insert them then rehot or reball UEM. i reballed uem and problem is solved thanks
Gee4234
Nokia 3220 - Insert Sim Card Seedy Nokia Hardware & Hardware Repair 25 08-01-2011 10:32
Nokia 3220 insert sim Sulation without sim IC enmuthukrishnan Nokia Hardware & Hardware Repair 2 03-29-2010 19:04
3220 insert sim vishu222 Nokia Digital Core Technology 4 ( DCT-4 ) 7 08-23-2006 11:44
3220 Insert Sim message rjmobile Nokia Digital Core Technology 4 ( DCT-4 ) 3 12-27-2005 10:12
3220 insert sim vishu222 Nokia Hardware & Hardware Repair 3 12-19-2005 21:22
Page generated in 0.20350 seconds with 10 queries
