Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 09-03-2005, 10:41   #1 (permalink)
Member: 129676
3220 local mode problem
hi every body
i have a problem with the local mode ... what chip is responsable for login the phone to the local mode???????
i have many cases for this
1-i have a 7610 water dameg when flash can't login to local mode and this problem is soloved by replasing the UEM .
2- i have a 6600 "contact retaler" and can't format user area becouse of local mode and solved also by replasing the glode UEm
now i have a 3220 water dameg can't extract content becouse it can't login local mode i replace the UEM & FLASH but the same problem it can't login local mode i flash it by twister & prodegy the same problem .so i need to now how is the responsable for login into local mode to solve this problem & other problem like it becouse i have also a 6600 white screen and shut of after 30 secand in the box he take a software but can't login local mode ???????
can any one give me a good openion for this problem ????
thanks for evry one.
Old 09-04-2005, 02:49   #2 (permalink)
Member: 108629
Check Bsi line broken link and then fix it ur problem will be solved
Old 09-10-2005, 22:36   #3 (permalink)
Member: 129676
thank
thank you man i will do it but is it for all nokia device becouse i see this problem in meny devices????
Old 09-23-2005, 09:00   #4 (permalink)
due
due's Avatar
Member: 52810
Red face
I HAVE APROPLEM WITH N6600 WHEN PWOR ON IT TAKE phone start-up failed.contact the retailer can any one help me pls nel
Old 09-23-2005, 09:07   #5 (permalink)
due
due's Avatar
Member: 52810
I HAVE APROPLEM WITH N6600 WHEN PWOR ON IT TAKE phone start-up failed.contact the retailer nel
Old 09-27-2005, 18:51   #6 (permalink)
Member: 129676
tested solution
i have the same problem and i solve it by formating user area with twister or prodegy if not working you can solve it by reblasment the uem ic
i hope it worked for you
Old 03-15-2006, 14:38   #7 (permalink)
Member: 241915
any other solutions than this.i have try all the above that you have mentioned.
Old 03-15-2006, 14:52   #8 (permalink)
Crazy Poster
Member: 220962
Originally Posted by sameh_safa
hi every body
@Sameh_safa: Do u have ufs-box? If u have this box, u have to erase three flash IC before flashing. See three address when u beginning flash with ufs (n-box). After "format user area", "full factory de..." the phone now okie! Good luck!
Old 03-20-2006, 21:47   #9 (permalink)
Member: 129676
thank you man it/s good idea
Old 05-13-2006, 11:03   #10 (permalink)
gsmawake's Avatar
Member: 274299
i have also this problem in 3220, cant local mode but connecting. where is the bsi line? can u show me some pic?
The Following User Says Thank You to gsmawake For This Useful Post:
Old 08-22-2006, 02:15   #11 (permalink)
Satyam321's Avatar
Member: 269198
e:mail me i give you or after i will send to all pic of bsi 3220
roshanjenet@servihoo.com
Old 08-23-2006, 01:00   #12 (permalink)
Member: 197538
@satyam321
Hey man it would be nice if u cqn post in the forum here cause i am sure many people need it and your help will be highly appreciatted but if not can u please also mail it to me as i have the same problem
muna66@hotmail.com
thanks
mike
Old 08-23-2006, 23:08   #13 (permalink)
Satyam321's Avatar
Member: 269198
hi guys
here the picture of bsi but im very bussy to search one same model pic
for 3220
i am sending you the same line in other model pic if not understand so send me one pic 3220 i will draw the line exactly
Old 08-29-2006, 12:00   #14 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
3220 can't extract content becouse it can't login local mode
solusion is :: upp
100 % tested by Tc
x_phone_tc@yahoo.com
tc
Old 08-29-2006, 13:35   #15 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
solusion is :: upp
100 % tested by Tc
tc
you can solve your problem by changing the erase adress......
start adress 01000000
end adress..01fffff change this adress 013fffff
it will solve your problem....
may be the erase prosess fails but dont worry
now you can flash your phone normally.... it will be alive
100% tested....
nokia 3220 local mode problem nazar2008 Nokia Hardware & Hardware-Repair Area 2 06-16-2008 08:09
3220 Local mode celluniversal Nokia Hardware & Hardware-Repair Area 4 06-12-2006 07:29
3220 local mode failed sanjeevnegi Nokia Digital Core Technology 4 ( DCT-4 ) 1 05-21-2006 07:58
3220 local mode failed minami824 Nokia Digital Core Technology 4 ( DCT-4 ) 1 05-20-2006 09:16
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.75688 seconds with 10 queries
