Old 07-27-2007, 10:09   #1 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 199
3220 no acess
hi i have got 3220 with no acess problem. changed pa form working phone but still error. write pm , erased flase and full flash again write pm but problem remains same. make jumper of antena switch but same problem.pls help some one
Old 07-27-2007, 14:12   #2 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 199
world's biggest forum and no one here who can help me. pls pls help someone
Old 07-27-2007, 16:45   #3 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
Still PA problem.
Change the PA again bro, with new one... You must install PA at 2 mins. or less than 2 minutes time.. or else u may damage the PA when u installing...
just be careful. Regards
Old 07-28-2007, 04:55   #4 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 199
sir i have replaced the PA from working phone to problem phone and PA from problem phone to working phone but problem not solved. but the pa from problem phone worked ok in other phone.
Old 07-28-2007, 07:52   #5 (permalink)
Member: 147187
Thanks Meter: 15
chek +voltage of the PA from battery connector +pin
Old 07-28-2007, 07:53   #6 (permalink)
Member: 147187
Thanks Meter: 15
and post the result 100% working
Old 07-28-2007, 09:28   #7 (permalink)
Member: 431326
check the rx filters and local oscilator br. hope it will work.
Old 07-28-2007, 09:59   #8 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 199
supply is ok and local oscilater is working cause it says no acess not no network found.
Old 07-28-2007, 15:06   #9 (permalink)
roshantelecom&s's Avatar
Member: 368546
Thanks Meter: 235
u just have to reball uem and nothing else 10000% working
Old 07-28-2007, 16:04   #10 (permalink)
techseeker"ems"'s Avatar
Member: 343227
Thanks Meter: 22
try to check serial if unit is blocklisted? better reflow or replace new uem and put a new rpl file then unlock unit.
Old 07-28-2007, 16:11   #11 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
100% uem problem, after change and written a new imei, no longer on blacklist
T29 no Acess gosev Sony Ericsson Hardware Repair 5 10-25-2005 09:08
2600 no network or no acess jon2 Nokia Digital Core Technology 4 ( DCT-4 ) 1 09-17-2005 07:36
T310 NO acess mobilemafia Sony Ericsson 6 09-08-2003 14:52
Page generated in 0.17575 seconds with 10 queries
