02-17-2007, 15:41 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: EGYPT-ZAGAZIG
Member: 234790 Status: Offline Thanks Meter: 4 | 3220 no network do u have any advice thnx hany the egyptian |
02-17-2007, 17:50 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | first flash the phone with good pm check ant switch check PA again if not solved then change filters near rf section post result |
02-18-2007, 05:57 | #6 (permalink) |
Freak Poster Join Date: Feb 2007 Location: pilipinas
Member: 445609 Status: Offline Thanks Meter: 27 | search the network manually thru ur pone.if d pone searches fast and no network found.change ur HAGAR.and if ur pone found network and no access(NO ACCESS)then chane its PA. |
07-12-2008, 18:15 | #8 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PILIPINAS
Member: 759375 Status: Offline Sonork: www.GSMPIONEER.com Thanks Meter: 895 | click FTD ON in jaf software before flashing it with jaf.... it will enable the FIELD TEST DEVELOPER in the unit... then you will see the net monitor after flashing...... it's gonna be much easier to check which parts is faulty with net monitoring.. after flashing go to menu then click the net monitor then type 0101.... then post the values.... rx tx etc.... |
Nokia 3220 no network | Albinas | Nokia Hardware & Hardware Repair | 8 | 07-18-2010 15:25 |
3220 no network help me,no rx no tx ,help me | shivam4you | Nokia Hardware & Hardware Repair | 1 | 03-09-2009 07:37 |
3220 no network and insert sim card | JeAn-cLeM | Nokia Hardware & Hardware Repair | 5 | 11-27-2008 13:04 |
3220 no network | genoma20 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 09-17-2005 11:01 |
3220 no network..but searching well manually | manish1234 | Nokia Hardware & Hardware Repair | 5 | 08-26-2005 16:07 |
