3220, where is problem phone is white secreen, no inclming no outgoing, when i start fleshing local mode appear on secreen, i full erase full flesh but same problem, uiseting fail where is problem, see log Detected: V 05.90 09-05-06 RH-37 (c) Nokia. 1st Boot: Ok, DCT4, UPP: 2142 [Rh-37] [2.0.8.4] 2nd Boot: u_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x01FFFFFF,00208804,St M36L0R7040U Algorithm: u_intel.fia, Ver: 4.76.0 Algorithm Ok, MSID: 84132419FBCAF45700A31E80B5 Decoded MSID: 2C40BAE9-005F21CB-AA000000 Encoded FAID: B724DFCD-33B9EB15-DA84D902 IMAGE: rh37__05.900 Area1: 0x01000000-0x0101FFFF Erased, Time: 00:01 Area2: 0x01020000-0x0181FFFF Erased, Time: 01:36 Area3: 0x01E60000-0x01FDFFFF Erased, Time: 00:18 MCU Flashing Completed, Time: 00:47 Chip SECTOR_SIZE: 128k, File FAT_SECTOR_SIZE: 64k Warning, Must be Used 128Kb Sector_Size CNT File IMAGE: rh37__05.90.image_india_128 Area1: 0x01A40000-0x01E5FFFF Erased, Time: 00:50 CNT Flashing Completed, Time: 00:14 Running: Nokia File Server CNT Extract Warning, Res: 0, CNT Area not Empty Contents Package Extracting Ok, Time: 00:07 1st Boot: Ok, DCT4, UPP: 2142 [Rh-37] [2.0.8.4] 2nd Boot: u_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x01FFFFFF,00208804,St M36L0R7040U Algorithm: u_intel.fia, Ver: 4.76.0 Algorithm Ok, MSID: 84E7B44C2BAB4BD2E65731F8F7 Decoded MSID: 3E4EBAE9-005F21CB-A9000000 Encoded FAID: E99D81C6-7F8AFB43-1BC6C83A IMAGE: rh37__05.90w Area1: 0x01820000-0x01A3FFFF Erased, Time: 00:25 PPM Flashing Completed, Time: 00:09 Flashing Completed, Rebooting Mobile IMEI: 352737-01-552764-2, ASIC: 2 SimLocks Initialized (NM Ok), Time: 00:00 Set UI Defaults ... Init Test Mode Failed |
can you post the full selftest information and try to flash with higher flash file,,, |
1 Attachment(s) Quote:
brother this is latest ver. mobile secreen show local/testmode but fail on flasher |
INFO IS HERE MCU SW : V 05.90 09-05-06 RH-37 (c) Nokia. PPM SW : V 05.90 09-05-06 RH-37 (c) Nokia. W Prd.Code: 0518260 Bpr.Code: 0519858 Prod.Sn : MRB431288 HW Vers : 5053 UEM : 400 UPP : 8514 [2142] RFIC Ver: 0205 DSP Vers: P05w06.v34_SLM LCD Type: AMAZON IMEI : 352737-01-552764-2 SL Conf : 001-01-00000000000 SL Prof : 000000000000000-2 SL Var : 00553527370155276400 SL Aux : 00025555 HW Sig : 6B23E0623D5AAF5C Box Id : 894FC821FA227304 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN MastCode: 55 01 11 16 34 Provider: GSM Test Equipment #pw+ 284 895 501 230 607 +1# #pw+ 483 317 301 155 426 +2# #pw+ 013 293 737 114 106 +3# #pw+ 787 890 003 540 304 +4# #pw+ 484 807 100 260 315 +5# #pw+ 858 921 172 671 731 +6# #pw+ 135 534 756 317 340 +7# |
INFO IS HERE MCU SW : V 05.90 09-05-06 RH-37 (c) Nokia. PPM SW : V 05.90 09-05-06 RH-37 (c) Nokia. W Prd.Code: 0518260 Bpr.Code: 0519858 Prod.Sn : MRB431288 HW Vers : 5053 UEM : 400 UPP : 8514 [2142] RFIC Ver: 0205 DSP Vers: P05w06.v34_SLM LCD Type: AMAZON IMEI : 352737-01-552764-2 SL Conf : 001-01-00000000000 SL Prof : 000000000000000-2 SL Var : 00553527370155276400 SL Aux : 00025555 HW Sig : 6B23E0623D5AAF5C Box Id : 894FC821FA227304 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN MastCode: 55 01 11 16 34 Provider: GSM Test Equipment #pw+ 284 895 501 230 607 +1# #pw+ 483 317 301 155 426 +2# #pw+ 013 293 737 114 106 +3# #pw+ 787 890 003 540 304 +4# #pw+ 484 807 100 260 315 +5# #pw+ 858 921 172 671 731 +6# #pw+ 135 534 756 317 340 +7# REMEMBER, when i power on phone it shows white secren (no incoming/outgoing)writing full pm init sim lock ok other uiseting fail when conect to ufs it shows local mode/test mode on secreen Init Local Mode Ok, Time: 00:00, Init Test Mode Failed Init Normal Mode Failed, Fatal Error chk this IMEI: 352737-01-552764-2, ASIC: 2 SimLocks Initialized (NM Ok), Time: 00:00 Set Security Ok, Time: 00:00 Set Full Factory Defaults ... Init Test Mode Failed |
rehot or reball cpu........................... |
i already reball cpu |
100% flash ic problem........... |
@zargar 1)check bsi line or reball UEM BSI LINE PROBLEM MAKE THIS PROBLEM 50% |
i solve the many white screen 3220 and 6020 set with reball camra ic |
1000% flash ic problem. rehot flash ic... |
set is water damage just wash and little heat wbr pankaj |
bro, i have 100% solution for this problem.just open the phone and flash without middle.when flashing complete then before click ui setting short bsi line with ground with tweezer ...ui setting complete...... i have tested it many 3220-6020-6070-6080 set's.................. |
