Old 06-11-2009, 16:16   #1 (permalink)
Member: 367928
Thanks Meter: 178
3220, where is problem
phone is white secreen, no inclming no outgoing, when i start fleshing local mode appear on secreen, i full erase full flesh but same problem, uiseting fail
where is problem, see log
Detected: V 05.90 09-05-06 RH-37 (c) Nokia.
1st Boot: Ok, DCT4, UPP: 2142 [Rh-37] [2.0.8.4]
2nd Boot: u_2nd.fia, Ver: 4.76.0
Fl0: 0x01000000-0x01FFFFFF,00208804,St M36L0R7040U
Algorithm: u_intel.fia, Ver: 4.76.0
Algorithm Ok, MSID: 84132419FBCAF45700A31E80B5
Decoded MSID: 2C40BAE9-005F21CB-AA000000
Encoded FAID: B724DFCD-33B9EB15-DA84D902
IMAGE: rh37__05.900
Area1: 0x01000000-0x0101FFFF Erased, Time: 00:01
Area2: 0x01020000-0x0181FFFF Erased, Time: 01:36
Area3: 0x01E60000-0x01FDFFFF Erased, Time: 00:18
MCU Flashing Completed, Time: 00:47
Chip SECTOR_SIZE: 128k, File FAT_SECTOR_SIZE: 64k
Warning, Must be Used 128Kb Sector_Size CNT File
IMAGE: rh37__05.90.image_india_128
Area1: 0x01A40000-0x01E5FFFF Erased, Time: 00:50
CNT Flashing Completed, Time: 00:14
Running: Nokia File Server
CNT Extract Warning, Res: 0, CNT Area not Empty
Contents Package Extracting Ok, Time: 00:07
Algorithm Ok, MSID: 84E7B44C2BAB4BD2E65731F8F7
Decoded MSID: 3E4EBAE9-005F21CB-A9000000
Encoded FAID: E99D81C6-7F8AFB43-1BC6C83A
IMAGE: rh37__05.90w
Area1: 0x01820000-0x01A3FFFF Erased, Time: 00:25
PPM Flashing Completed, Time: 00:09
Flashing Completed, Rebooting Mobile
IMEI: 352737-01-552764-2, ASIC: 2
SimLocks Initialized (NM Ok), Time: 00:00
Set UI Defaults ...
Init Test Mode Failed
Old 06-11-2009, 16:28   #2 (permalink)
mobileunlockers's Avatar
Member: 396778
Thanks Meter: 152
can you post the full selftest information and try to flash with higher flash file,,,
Old 06-11-2009, 17:08   #3 (permalink)
Member: 367928
Thanks Meter: 178
here is test report all ok in selftest
brother this is latest ver.
mobile secreen show local/testmode but fail on flasher
Old 06-11-2009, 20:15   #4 (permalink)
Member: 367928
Thanks Meter: 178
INFO IS HERE
MCU SW : V 05.90 09-05-06 RH-37 (c) Nokia.
PPM SW : V 05.90 09-05-06 RH-37 (c) Nokia. W
Prd.Code: 0518260
Bpr.Code: 0519858
Prod.Sn : MRB431288
HW Vers : 5053
UEM : 400
UPP : 8514 [2142]
RFIC Ver: 0205
DSP Vers: P05w06.v34_SLM
LCD Type: AMAZON
IMEI : 352737-01-552764-2
SL Conf : 001-01-00000000000
SL Prof : 000000000000000-2
SL Var : 00553527370155276400
SL Aux : 00025555
HW Sig : 6B23E0623D5AAF5C
Box Id : 894FC821FA227304
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
MastCode: 55 01 11 16 34
Provider: GSM Test Equipment
#pw+ 284 895 501 230 607 +1#
#pw+ 483 317 301 155 426 +2#
#pw+ 013 293 737 114 106 +3#
#pw+ 787 890 003 540 304 +4#
#pw+ 484 807 100 260 315 +5#
#pw+ 858 921 172 671 731 +6#
#pw+ 135 534 756 317 340 +7#
Old 06-11-2009, 20:27   #5 (permalink)
Member: 367928
Thanks Meter: 178
INFO IS HERE
Prd.Code: 0518260
Bpr.Code: 0519858
Prod.Sn : MRB431288
HW Vers : 5053
UEM : 400
UPP : 8514 [2142]
RFIC Ver: 0205
LCD Type: AMAZON
SL Aux : 00025555
REMEMBER, when i power on phone it shows white secren (no incoming/outgoing)writing full pm init sim lock ok other uiseting fail
when conect to ufs it shows local mode/test mode on secreen
Init Local Mode Ok, Time: 00:00,
Init Normal Mode Failed, Fatal Error
chk this
Set Security Ok, Time: 00:00
Set Full Factory Defaults ...
Old 06-11-2009, 20:35   #6 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,374
rehot or reball cpu...........................
Old 06-12-2009, 06:17   #7 (permalink)
Member: 367928
Thanks Meter: 178
i already reball cpu
Old 06-12-2009, 06:21   #8 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 570
100% flash ic problem...........
Old 06-12-2009, 06:29   #9 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,429
brothers,flash ic and UPP not make this problem
@zargar
1)check bsi line or reball UEM
BSI LINE PROBLEM MAKE THIS PROBLEM 50%
Old 06-12-2009, 07:00   #10 (permalink)
deepaksawdia's Avatar
Member: 108186
Thanks Meter: 241
i solve the many white screen 3220 and 6020 set with reball camra ic
Old 06-27-2009, 21:42   #11 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
1000% flash ic problem.
rehot flash ic...
Old 06-28-2009, 13:11   #12 (permalink)
Member: 983750
Thanks Meter: 26
set is water damage
just wash and little heat
wbr
pankaj
Old 06-28-2009, 13:24   #13 (permalink)
s.s.s.s.'s Avatar
Member: 988641
Sonork: sanjay chaudhary
Thanks Meter: 342
bro,
i have 100% solution for this problem.just open the phone and flash without middle.when flashing complete then before click ui setting short bsi line with ground with tweezer ...ui setting complete......
i have tested it many 3220-6020-6070-6080 set's..................
where is problem rehman9 LG 6 06-21-2006 12:39
where is problem rehman9 FuriouS II 13 06-01-2006 13:30
where is problem snipergsm FuriouS II 7 05-22-2006 20:14
Where is problem? pirat-bg x1x to x45/x50 1 09-23-2002 01:53
Where is problem with C35i flasher RoMa x1x to x45/x50 0 09-09-2000 21:39
Page generated in 0.48614 seconds with 9 queries
