08-04-2008, 13:52 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: chttagong
Member: 571857 Status: Offline Thanks Meter: 20 | 3220flash problem MCU ID: 0x2142 FLASH ID0: 88260020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\356236006080642_imei_back up_183748.rpl Done! Backup imei OK! Flashing Done! Operation took 0 minutes 10 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-37, Software version: 05.90 IMEI: 356236006080642 Product Code: 0520475 Resetting PPC... Done! Changing mode... Done! Setting local mode... Reading... Phone Type: RH-37 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.300 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.300 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.300 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.30a CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.300 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.30a CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.30u ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\356236006080642_imei_back up_183948.rpl Done! Backup imei OK! MCU: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.300 Booting phone... MCU ID: 0x2142 This MCU ID is not supported in chosen flash file... Error booting phone... Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\356236006080642_imei_back up_183948.rpl Done! Backup imei OK! MCU: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.300 Booting phone... MCU ID: 0x2142 This MCU ID is not supported in chosen flash file... Error booting phone... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.300 Booting phone... MCU ID: 0x2142 This MCU ID is not supported in chosen flash file... Error booting phone... Backup IMEI zone... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\356236006080642_imei_back up_184048.rpl Done! Getting MCUID... MCU ID: 0x2142 Reading flash chip detailes... FLASH ID0: 88260020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2142 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! MCU: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__03.300 Booting phone... MCU ID: 0x2142 This MCU ID is not supported in chosen flash file... Error booting phone... INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__05.900 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__05.90a CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__05.90.image_a ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic MCU: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__05.900 Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 88260020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x26882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B28; Loader chk: 35 Loader is ready... P-key nokia module version 01.02 MSID: 84D62D6FDCB9DBEE3C3580E395 MSID decoded: 2C40BAE9000309E6AA000000 FAID: 5956B3BDDD373FC0EDF3F253 Operation took 0 minutes 15 seconds... Erasing... Found 3 interval(s) to erase Erasing area: 01000000 - 0101FFFF... Erasing area: 01020000 - 0181FFFF... Erasing area: 01E60000 - 01FDFFFF... Operation took 1 minutes 30 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 46 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__05.90.image_a Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 88260020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x26882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B28; Loader chk: 35 Loader is ready... P-key nokia module version 01.02 MSID: 847F3E0BFC22C33212D7505B6C MSID decoded: 1C15BAE3000309E6AD0005BD FAID: 4CDCCD848F7937F297683531 Operation took 0 minutes 14 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01A40000 - 01E5FFFF... Operation took 0 minutes 39 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 14 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Extracting Content Pack... Error setting local mode... CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\RH-37\rh37__05.90a Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 88260020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x26882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B28; Loader chk: d5 Loader is ready... P-key nokia module version 01.02 MSID: 840003A2BF9DDE4EAA2B13632F MSID decoded: 3E4EBAE9000309E6A9000000 FAID: 010AC35AE2FDD9E7BFDAEA7C Operation took 0 minutes 15 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 01820000 - 01A3FFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Flashing Done! Operation took 5 minutes 1 seconds... |
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems | GsmMunna | HWK | 1801 | 05-18-2023 13:08 |
unlocking 8350i problem [ANSWERED] | NeeMan | PolarBox 3 | 5 | 03-29-2010 19:21 |
POTATO interfeis problem | lipen | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-29-2010 17:01 |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
