Old 05-20-2006, 08:24   #1 (permalink)
Member: 268930
Thanks Meter: 23
3230 camera problem
Hi masters I have Nokia 3230 it have a problem when i on the camera then it says future not sported I flash it user fomat Area and Ui option and manually formating but problem is sam pleas Help me what is solution
The Following User Says Thank You to skd_123 For This Useful Post:
Old 05-20-2006, 08:55   #2 (permalink)
Member: 145438
Thanks Meter: 4
firstly you must confirm that the camera is working before if so remove the camera carefully and heat the board for while goodluck
The Following 2 Users Say Thank You to hurla For This Useful Post:
Old 10-22-2008, 09:30   #3 (permalink)
Member: 820739
Thanks Meter: 2
sir i have the same problem, i did what you told but still the problem is there...is there any jumper solution for this?
The Following User Says Thank You to atheniankid For This Useful Post:
Old 10-22-2008, 09:42   #4 (permalink)
mobilelink's Avatar
Member: 318277
Thanks Meter: 92
Mate
First flash the phone and checkif not ,now change the camera ..is the issue still remains Change front PCB..post results
The Following User Says Thank You to mobilelink For This Useful Post:
Old 10-22-2008, 09:46   #5 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 271
3230 camera feature not supported
hi bro...
change the flex of keyboard your problem will be solved.
good luck............
The Following User Says Thank You to shuaib_kashish For This Useful Post:
3230 Camera Problem- 'system Error' jamohaki Nokia Hardware & Hardware Repair 4 07-26-2009 05:17
3230 camera problem BMobile WD2 & APE (Symbian Phones) 8 04-28-2008 09:38
3230 Camera Problem SATISH WD2 & APE (Symbian Phones) 7 07-13-2006 18:40
3230 camera problem jasonng78 WD2 & APE (Symbian Phones) 1 04-01-2006 05:54
Page generated in 0.14984 seconds with 9 queries
