Old 09-11-2008, 11:20   #1 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
Red face 3230 camera problem
helloo dear frens my have one 3230 camera problem.when i try show me "featuret no supported"
can any body help me,,,wit pic
i already change ui boat and camera,and also give one jumper,,,,
problem is same,,,software alo try,,,
hurry up dear frens,,,
Old 09-11-2008, 12:50   #2 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
Originally Posted by gsmshare View Post
helloo dear frens my have one 3230 camera problem.when i try show me "feature not supported"
no body can answer my problem,,,what the man,,,give me solution,,,here so many ppl some one also don't know this solution??
hurry up,,,,masters,,,help me
Old 09-11-2008, 13:11   #3 (permalink)
Member: 834621
hi 1ic camera 2 camera 3 uif
Old 09-11-2008, 13:20   #4 (permalink)
ucokmonalisa's Avatar
Member: 527741
Thanks Meter: 355
try here
Quote
Original Posted By > tkowsar
see me
http://forum.gsmhosting.com/vbb/showthread.php?t=438356
just change ur flex cable, or frontpart with flex cable, problem solv.
or try here
http://www.4shared.com/file/62586324...mere_3230.html
B.R
ucokmonalisa
Old 09-11-2008, 13:21   #5 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
what you talk, are you know ????
Old 09-11-2008, 13:23   #6 (permalink)
Member: 659586
Thanks Meter: 86
try with jumper or change X012 connector...
salam.
The Following 2 Users Say Thank You to arnold marpaung For This Useful Post:
Old 09-11-2008, 13:27   #7 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
salam.
i will post result,,,now i try this
Old 09-11-2008, 13:33   #8 (permalink)
Member: 659586
Thanks Meter: 86
hopefully friend success..
salam from medan~indonesia.
wow...salam to you mister ucok monalisa..
Old 09-11-2008, 13:38   #9 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
hey dear arnold marpauong picture is not clear,,,,,near the flexi cable,,,,can u another and can u add me my yahoo,,,,if u want
Old 09-11-2008, 13:46   #10 (permalink)
Member: 659586
Thanks Meter: 86
ok..I try to redo..and I await in ym..
Old 09-11-2008, 13:54   #11 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 183
some time with change ui board it doesn't works.
there are three conectors on ui and also in main pcb(motherboard).
mainly one is for lcd, one is for keypad and one is for camara (right one)
in my experience i faced these kinds of prob.
it is conector prob> change conector if u can do this properly
or cut a visiting paper slide, make packin under two conectors (right one which is for camara)
Old 09-11-2008, 18:53   #12 (permalink)
abheejeet's Avatar
Member: 811063
Thanks Meter: 203
cheng u r camera if is it water damege
Old 09-11-2008, 22:36   #13 (permalink)
Member: 675717
Thanks Meter: 125
What is the problem i have two UI board both 100% ok if i exchange camera feture not suported.
Old 09-12-2008, 04:07   #14 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
this is not UI problem,,,i already do this is right socket problem (in mother board),,,
try this ,,,all the best
Old 09-12-2008, 05:51   #15 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
yes,,,i solved the problem,,,,just change x012 socket,,,,
3230 camera problem skd_123 Nokia Hardware & Hardware Repair 4 10-22-2008 09:46
3230 camera problem BMobile WD2 & APE (Symbian Phones) 8 04-28-2008 09:38
3230 Camera Problem SATISH WD2 & APE (Symbian Phones) 7 07-13-2006 18:40
3230 camera problem jasonng78 WD2 & APE (Symbian Phones) 1 04-01-2006 05:54
Page generated in 0.24258 seconds with 10 queries
