Old 11-20-2005, 11:42   #1 (permalink)
Member: 25763
Thanks Meter: 18
Thumbs up 3230 Display Blank Solution
Dear All
I have Nokia 3230 with Blank Display..Software is OK..Display IC Changed..Display Driver IC changed..Display Changed..UI Module changed..but problem is same.Somebody pls suggest what is to be done.
Regards
The Following 5 Users Say Thank You to supremegsm For This Useful Post:
Old 11-20-2005, 11:47   #2 (permalink)
inat's Avatar
Member: 149576
Thanks Meter: 56
3230 Display Blank
have u check the LCD already ?????
Old 11-20-2005, 11:55   #3 (permalink)
Member: 25763
Thanks Meter: 18
Yes ..have changed LCD also and checked
Old 11-21-2005, 02:40   #4 (permalink)
Member: 149014
Thanks Meter: 3
try to change small flat cable between 2 pcb.....maybe this help
Old 11-21-2005, 04:19   #5 (permalink)
hiteshsangadia's Avatar
Member: 109136
Thanks Meter: 17
yes solution is change strip connecting 2 pcb or just heat strip connectins
i have done it... 100% works
Old 11-21-2005, 04:48   #6 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,043
Hi
SOME TIME SOFTWARE PROBLAM TO.. SOME TIME'S HARDWARE BATTER YOU TRY WITH SOFTWARE ERASE FLASH AN TRY TO FLASH WITH NEW VER......
WBR
MUNNA
WWW.GSMMUNNA.COM
Old 11-21-2005, 09:00   #7 (permalink)
Member: 43545
Thanks Meter: 7
ya mates its rite problem wid flex cable ....but problem wid how to fix that small flex cable ....i m try but i m not success .....is thata any tips ....how to fix that smalll flex cable....thyanks
Old 12-11-2005, 03:10   #8 (permalink)
Member: 142704
Thanks Meter: 9
Originally Posted by supremegsm
Dear All
Regards
that is not the solution the solution you need to search for the pm after that you flash the phnoe with compatible version
step after you have finshed flashing the phone yopu need to fomat the user arear 10 time and full factory default
thanks for more solution sontact +234823657689
or 234027511545 thanks
The Following User Says Thank You to koolzykoller For This Useful Post:
Old 12-11-2005, 14:06   #9 (permalink)
Member: 142734
Thanks Meter: 2
try to reset ur phone wid the code wid switch on button. idon't remember the code i think * + 3 + calling button then switch on button till ur phone goes to formatting screen. ur prob will be solved.
Old 12-11-2005, 15:22   #10 (permalink)
Member: 33445
Thanks Meter: 19
WBR
MUNNA
WWW.GSMMUNNA.COM
What Is The Process To Enter In Your Download Section Brother
Old 12-13-2005, 09:16   #11 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,043
hi cellclinic
SITE IS STILL UNDER DEVELOPMENT.... UPLODING GOING ON.....
WBR
MUNNA BHAI
WWW.GSMMUNNA.COM
Old 12-29-2005, 18:48   #12 (permalink)
Member: 154703
3220 display white
yes ı have same problem nokia 3220 phone ,display is white please helpme
Old 12-30-2005, 02:42   #13 (permalink)
Member: 149014
Thanks Meter: 3
change theLCD PCB with small flat kable this 100% work tested in 5 phones and all work fine after replasment,enjoy :-)
Old 12-31-2005, 00:19   #14 (permalink)
Member: 215010
thanks gayes for help
Old 12-31-2005, 08:19   #15 (permalink)
Member: 137686
Thanks Meter: 3
try changed lcd but not close u'r problem, please try changed flexibel.
gud luck mannn
The Following User Says Thank You to HP-King For This Useful Post:
7610-6670-3230-6600 blank screen solution!! υИқИΘШИ WD2 & APE (Symbian Phones) 25 09-21-2009 18:43
nokia 3230 display blank vimochan80 Nokia Hardware & Hardware Repair 3 11-30-2008 14:49
help, nokia 3230 lcd blank... Schnitzer Nokia Hardware & Hardware Repair 1 04-22-2006 23:22
Display BLANK after Flashing SL45!!! NEED HELP, PLSS!! nickfg x1x to x45/x50 8 01-10-2003 01:07
Page generated in 0.43179 seconds with 9 queries
