04-05-2007, 06:00 | #4 (permalink) |
Junior Member Join Date: Jan 2007 Location: rajkot-(india)
Member: 427330 Status: Offline Thanks Meter: 0 | 3230 white light most of this type problems related because of flex belt. chang belt or display board. check your display also. it the problem is same go to main pcb and check display related parts. |
04-05-2007, 08:26 | #5 (permalink) |
Freak Poster Join Date: Aug 2005 Location: india,mumbai Age: 50
Member: 175555 Status: Offline Thanks Meter: 12 | change the first connecter from the board which is on right hand side i had solved that problem with that just try tht i think he problem is from that only |
12-31-2007, 08:02 | #7 (permalink) | |
Moderator Join Date: Feb 2006 Location: Bangladesh & Bahrain
Member: 233205 Status: Offline Thanks Meter: 5,014 | Quote:
problem is where? in ur flex cable with front board or ur back bord display ic or flex socket. so test ur frond board/display board replace with ok same phone. though ur front board ok try to change display IC though not ok change ur flex cable, better is though u replace a new front board. also see my attach pic, may u solv ur problem. best of luck tkowsar | |
The Following User Says Thank You to tkowsar For This Useful Post: |
12-31-2007, 10:18 | #9 (permalink) |
Freak Poster Join Date: Jul 2007 Location: EASY PHONE.LLC-SATWA,UAE Age: 35
Member: 542150 Status: Offline Thanks Meter: 126 | first check the disply front board and then most problems the disply connecter<main board> change the conector,and check the prints |
01-06-2008, 17:45 | #10 (permalink) |
Junior Member Join Date: Oct 2006
Member: 361222 Status: Offline Thanks Meter: 0 | nok need to replace any thing Hello, I have the same problem in my nokia 3230, all technicians said that I have to replace parts. I decided to open it my self and I just dismantle the phone on pieces after I verify the connection between the differnet electronic cards and with the keyboard after that every thing is OK 1000000% believe me Good luck |
nokia 3230 display problem | nomi | Nokia Hardware & Hardware Repair | 21 | 10-13-2010 10:09 |
3230 display problem | ihmgsm | WD2 & APE (Symbian Phones) | 11 | 02-25-2008 03:20 |
pls help 3230 display problem .......... | mail1q | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 11-25-2007 19:23 |
3230 display problem | bmc_mobiledoc | WD2 & APE (Symbian Phones) | 2 | 04-19-2006 09:27 |
3230 Display Problem | relish | Nokia Hardware & Hardware Repair | 2 | 02-26-2006 18:37 |
