3230 fleshing After flash processing... Waiting for phone to boot... Reading... Failed! Aborting!...MCUVER |
erase flash then full flash post again |
same problem............................. |
erase flash wr flash ppm formatte UI setting step by step,,,,if you follow my instruction may be solved ur problem 100% best of luck |
flash it with higher version bro.. |
whice ver use brother. |
*+3+yes power try it. |
version is RM51PE506040.C1(mcu) and now u know what the ppm,,,, erase,,flash,,wr pm,fromatte,ui option,, thats it |
Change boot ic near battry connecter your problam 100% solved. Your problam i phone is not go to local mode |
3230 fleshing i try every idea but only 5times nokialogo and sutdown |
tell me details,,,what ur problem,,,if phone is ok,,must can run,,,just tell what happend |
flash latasst version |
3230 fleshing first problem white light, i try fleshing but no unlocks and formet then chenge boot ic but same becuse five times nokia and phone swich off |
rehot upp,,then erase, flash,wr pm,fromatte,ui setting.thats it if all run good still have white screen try change ui board,,,coz alwiz uio board problem,, try it i wait here,,, |
