Old 05-06-2009, 15:33   #1 (permalink)
Member: 269126
Sonork: 100.1616382
Thanks Meter: 370
3230 hang at nokia
seee log
whts the problem hardware or software
Powering the phone...
Reading...
MCU SW version: V 5.0717.0ch
04-05-07
RM-51
(c)NMP
HW version: 0584
PCI version:
UEM version: 144
UPP version: 4225
RFIC version: 0205
DSP version: B0439U_05w33
PPM version: V 5.0717.0ch
04-05-07
RM-51
(c)NMP.29
Production serial number: DNA772770
Product code: 0522253
Module code: 0202511
Basic production code: 0519957
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: h?????????????????????????????????????????????????
Default SN type: h?????????????????????????????????????????????????
IMEI plain: 356664007808622
IMEI spare to net: 3A 65 66 04 70 08 68 02
IMEI SV to net: 33 65 66 04 70 08 68 12 F4
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 5240063437
Phone type: RM-51, Software version: 5.0717.0ch, Language Pack: 29
User code: 12345
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-51.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0522253
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-51\
Scanning for ini files...
INI file 0522253.ini is missing. Continue searching for second ini type...
Searching for default location of ini...
Checking path: \Products\RM-51\
Searching for JAF saved location of ini...
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Done!
Old 05-06-2009, 19:28   #2 (permalink)
Member: 555190
Thanks Meter: 22
first try to get info.. if no info so try and try when saw full info on screen then formate. after formate do full factory defalts.....good luck
Old 05-07-2009, 16:18   #3 (permalink)
Member: 269126
Sonork: 100.1616382
Thanks Meter: 370
no luck many times done
Old 05-09-2009, 06:56   #4 (permalink)
Member: 869572
Thanks Meter: 13
change boot ic and rehot
Old 05-09-2009, 08:04   #5 (permalink)
Allunlockingsource's Avatar
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
Originally Posted by malikasim View Post
seee log
Reading...
04-05-07
RM-51
(c)NMP
HW version: 0584
PCI version:
UEM version: 144
UPP version: 4225
RFIC version: 0205
04-05-07
RM-51
(c)NMP.29
Flash code:
Order number:
Long production SN:
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
Brother only format your mobile with ............... press together botton............ * 3 Send Power and post result .
Old 05-09-2009, 09:18   #6 (permalink)
rangan_kumar's Avatar
Member: 596177
Thanks Meter: 156
seee log
Reading...
04-05-07
RM-51
(c)NMP
HW version: 0584
PCI version:
UEM version: 144
UPP version: 4225
RFIC version: 0205
04-05-07
RM-51
(c)NMP.29
Flash code:
Order number:
Long production SN:
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
sir. your phone hardwore problem.i am many set startup hang only nokia
chang boot ic 100% ok plz try boot ic.
thanks................
The Following User Says Thank You to rangan_kumar For This Useful Post:
Old 05-09-2009, 12:28   #7 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
try this
@malikasim bro do not try in hardware first try this
1- with ufs box start to erase manual this adress
start: 00000000 end: 00FFFFFF
start: 02000000 end: 02FFFFFF
start: 04000000 end: 047FFFFF
this 3 adress will eras the 3 flash's and u will not lost ur phone imei
2- with ufs again erase
start: 00010000 end: 0000FFFF
start: 02000000 end: 00FFFFFF
start: 02FC0000 end: 0286FFFF
start: 02A00000 end: 0000FFFF
3- flash ur phone with latest firmware
4- write full pm to ur phone
5- unlock and format user area
br
kalpesh
Old 05-09-2009, 12:32   #8 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
If still not done chack change lcd ui pcb i hope it's work
br.dynet
Old 05-09-2009, 15:06   #9 (permalink)
Member: 269126
Sonork: 100.1616382
Thanks Meter: 370
boot ic one print missing
.... red point missing
Old 05-10-2009, 05:40   #10 (permalink)
Registered User
Member: 677837
Thanks Meter: 65
bro just format manually with * 3 send and onoff button,press these button at a time,and post result
3230 hang at nokia malikasim WD2 & APE (Symbian Phones) 5 05-25-2009 06:05
3230 hang at nokia malikasim Nokia Hardware & Hardware Repair 6 05-07-2009 05:50
Nokia 3230 hangs on NOKIA ajit bs Nokia Hardware & Hardware Repair 7 08-24-2008 08:27
nokia 3230 hang on nokia startap binthabit Nokia Hardware & Hardware Repair 9 07-23-2008 09:54
Page generated in 0.31768 seconds with 10 queries
