3230 keybad 3230 some key bad disable. any ideas. |
hi mate, the most common problem of n3230 is the ui board, not the whole thing but the weakest part of the ui board is its flex cable. if you can find a replacement flex cable then try to replace it, if cant find any then tou have to replace the whole ui board. expensive problem!! |
thanks mate its really so expensive problem!! any other solution???????? |
well trace it one by one the connection. hardwork;) |
it can help you 1 Attachment(s) try with this man it can help you:D :D :D :D :D :D :D :D :D [[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[ ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] [[[[[[[[[[[[[[[[[[[[[[[ ]]]]]]]]]]]]] [[[[[[[ ]]] [ YASSER DREAM |
dear i solved my problem toooooooooo late. |
:D :D :D ............ :D :D :D |
GOOD LUCK YASSER DREAM:) :) :) |
