10-14-2006, 08:43 | #4 (permalink) |
Freak Poster Join Date: Mar 2006 Location: rajkot (india)
Member: 244357 Status: Offline Thanks Meter: 70 | 3250 camera problem just change the belt to connect both parts it will be ok. it is available in the market easy. |
The Following User Says Thank You to bhardwajparesh For This Useful Post: |
10-14-2006, 13:50 | #5 (permalink) |
Freak Poster Join Date: Dec 2005 Location: UEM
Member: 207453 Status: Offline Thanks Meter: 14 | hi dear, 1)check with new camera 2)check camera flex cable 3)check camera connector check their voltages etc,. regards abdulrahman |
The Following User Says Thank You to abdulrahman For This Useful Post: |
07-18-2008, 14:58 | #8 (permalink) | |
Major Poster Join Date: Jan 2008 Location: ZIMBABWE
Member: 677397 Status: Offline Thanks Meter: 7 | Quote:
thanks in advance. | |
The Following User Says Thank You to vilcon For This Useful Post: |
07-26-2008, 15:56 | #13 (permalink) |
Member: 677397 Status: Offline Thanks Meter: 7 | may you send me a picture. that will be better for other forum members. however, thanks for the post. |
09-26-2008, 13:14 | #15 (permalink) |
Junior Member Join Date: Sep 2008
Member: 860170 Status: Offline Thanks Meter: 3 | I have the same problem i make amistake but i took its feed back I changed the camera flat cable without connecting the cammera I THOUGHT that it will work with out giving image but the phone give [un supported feature] when i connect the camera the same message at last i remove the coil above the lower part flat cable socette on the board it works so good |
The Following User Says Thank You to sonoace_control For This Useful Post: |
3250 camera problem "camera on standby" | ..::ApexComm::.. | Nokia Hardware & Hardware Repair | 7 | 06-15-2008 13:35 |
3250 camera problem | honeytelecom | Nokia Hardware & Hardware Repair | 1 | 06-21-2007 12:00 |
3250 camera problem "camera on standby" | ..::ApexComm::.. | Nokia Base Band 5 ( BB-5 ) | 2 | 01-08-2007 20:59 |
3250 camera problem | belenm40 | Nokia Base Band 5 ( BB-5 ) | 1 | 08-23-2006 14:11 |
@^Help-3250 Camera Problem!^@ | ninja_ashu | Nokia Multimedia | 7 | 07-15-2006 21:56 |
