05-06-2002, 19:43 | #1 (permalink) |
Insane Poster Join Date: Jan 2002 Location: Netherland
Member: 8366 Status: Offline Thanks Meter: 0 | 33/32/61/62/ Nokia - Not Charging Can any one suggest how to repeare the phone's charging problem ? I have hier different Nokia's 3310/3210/6150/6210/ each of plugs indicet 6V, but the battery contacts shows only 1-1,2 V. I"ll appreciate any velueble respons. Best regards Gennady |
05-07-2002, 10:23 | #2 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Hello Could you explain more info about your problem? like what do you mean for measure the battery contact only 1-2v? is it after charging ? and have you try to measure the charging current? for normally 6v input for your 1-2v battery the charging current will about 700-900ma, for comon case power I.C will very easy to cause such problems. by the way some times it also just the charging parameters incorrect you have to run the energy management calibration . etc etc... |
All Nokia Not Charging,sine End Charging Problem Here | gsm st | Nokia Hardware & Hardware Repair | 5 | 11-20-2007 08:40 |
2600 nokia not charge help me | mobilerepair1 | Nokia Hardware & Hardware Repair | 6 | 04-12-2006 13:14 |
5140 nokia not charging solution | karouk | Nokia Hardware & Hardware Repair | 0 | 06-04-2005 01:06 |
