Old 10-17-2004, 20:38   #1 (permalink)
Member: 52884
Thanks Meter: 13
Cool 3310
hi all when i was going throught my repair book i saw this connection,maybe someone could pls tell me what it means there is connecting line from C575 the big creamic beside the PA to L513 to the +ve of the battery terminal topoint 4,5 of the PA.i think it is about network.can someone pls,pls explain to me better.
Old 10-17-2004, 20:43   #2 (permalink)
Member: 44625
Thanks Meter: 36
Its the power supply line to the PA. Check continuity when u have network problems as in signal bars dropping after a few seconds.
Old 10-18-2004, 14:48   #3 (permalink)
Member: 52884
Thanks Meter: 13
Cool
thanks for the reply,are you now saying that if there is a drop in signal i can do a jump wire and it will improve the signal.will it?
Old 10-19-2004, 17:43   #4 (permalink)
Cat10's Avatar
Member: 42123
Thanks Meter: 2
If signal drop or no network check the line power supply of PA if broken reconstruct the track.
regards
Old 10-20-2004, 19:52   #5 (permalink)
Member: 44625
Thanks Meter: 36
It will definitely improve signal if the track is broken. Else the PA may be faulty if the track is good and u still have the same problem.
Old 10-22-2004, 20:02   #6 (permalink)
Member: 52884
Thanks Meter: 13
Cool
if the line are not broken and and still the signal keeps disappearing and after changing the PA 2times now and still the same thing.any other solution
Old 10-22-2004, 20:58   #7 (permalink)
Member: 55600
Thanks Meter: 4
try to replace antenna switch (on the righ hand side of PA) base is usually ceramic ,cracks when dropped on the ground.
Old 10-22-2004, 22:29   #8 (permalink)
Member: 44625
Thanks Meter: 36
Could be cobba problem. Try reballing or replace with good one.
3310 DAED AND 3310 NO NETWORK ezz2003 Nokia Hardware & Hardware Repair 9 06-16-2007 18:03
3310 locked and 3310 without italian language ! dadleit Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 10-17-2002 11:23
3310 v4.02 -> 3310 v5.57 ? celo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 09-19-2002 02:39
3310 ver 5.47 and 3310 to 3315 Ramiz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 05-16-2002 17:15
3310 Into 6210 Or 3310 Into 6210 voxsam Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-14-2002 19:53
Page generated in 0.18495 seconds with 9 queries
