Old 07-14-2002, 17:26   #1 (permalink)
Member: 13660
Post 3310, 3210 charging problem
I have 3310 and 3210 and both while charger is connected are getting heat in upper part of the phone. The charging progress is shown on lcd but battery is not charging. Any ideas ?
Old 07-15-2002, 00:35   #2 (permalink)
Member: 13660
3310 is already repaired - I changed PA and now the phone is OK.
But 3210 is stil having problems. When I connect the charger the strange things are appearing on the lcd (line moving form the top to the bottom of lcd). I changed ccont but it did not help. Maybe chaps (N101) needs to be replaced but I don't have one at present. Anyone could help ?
Old 07-15-2002, 00:41   #3 (permalink)
doubleB's Avatar
Member: 13341
Re: 3310, 3210 charging problem
3210....change charging IC same solution if ur using d fone after few seconds it automatically turns off....
Nokia 3210 charging problem YamahaR1 Nokia Hardware & Hardware Repair 17 08-17-2012 14:36
Nokia 3210 charging problem Batgoy Nokia Hardware & Hardware Repair 4 01-14-2003 18:03
3210 charging problem j_h_u_n Nokia Hardware & Hardware Repair 4 08-10-2002 04:12
6210 & 3210 charging problem tagoy Nokia Hardware & Hardware Repair 3 03-07-2002 18:45
3210 charging problem???? sawa Nokia Hardware & Hardware Repair 1 12-28-2001 09:46
Page generated in 0.17869 seconds with 10 queries
