08-15-2001, 19:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | 3310 and 8250 Charging problems 1) 3310 not charging. Unit has not been dropped. 2) 8250 when you plug to charger and then unplug, battery indicator continues to show that it is charging. Suggestions are welcome. Thanks m8s |
08-15-2001, 21:30 | #2 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Tuzla, Bosnia and Herzegovina
Member: 3061 Status: Offline Thanks Meter: 0 | Hi, For 3310 if message is "not charging" then first check battery connector ( if btemp is not ok then message "not charging" displayed),<br />then you must check ( look on schematics ) r200, r203, r205, r208, r221, r222, and if all OK check N200 if ok then problem is PCB board.<br />If phone does not detect charger, first check fuse (f200) , inductor L202, and ressistors R209 and R210,<br />Note: all data is from nokia troubleshooting for 3310 .... For 8250 i don't know, maybe software bug <img src="rolleyes.gif" border="0"> Best regards ... |
08-18-2001, 05:20 | #3 (permalink) |
Freak Poster Join Date: Apr 2001 Location: INDIA
Member: 4223 Status: Offline Thanks Meter: 4 | Hello Hanukkah Again... Why don't u check the same IC of 8250 for this fault as it is in 8210 (low battrey fault)... U will b happy guy. And for 3310 do it as digit4l says... Charging problem is not a big problem dear <img src="wink.gif" border="0"> . <br />Good luck. <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> |
08-18-2001, 17:19 | #5 (permalink) |
Insane Poster Join Date: May 2001 Location: The Netherlands
Member: 4451 Status: Offline Thanks Meter: 0 | Hi I have a 7110 V04.80 and when I put the battery on the phone the phone gives a BEEP and the charging symbol will show "without the charger connected" also you can see there is a little voltage on the screen when the phone is off because the background of the screen is a little bit darker then without the battery. So when the phone is off the battery will still become ends empty. When I put it on the phone say's after a while "Not charging" (still no charger connected). Even with the charger connected it won't charge. I checked the battery on a other phone and this is not the problem. The phone itself works OK. Does anyone know this problem or can HELP me with this problem.<br />Regards,<br />Fallen <img src="rolleyes.gif" border="0"> |
NOKIA 3310 and UFS-3 problem!!!! | Mehvishal | UFS2 + UFS3-Tornadoflasher | 6 | 11-02-2004 19:24 |
5110 and 6210 charging problem? | Abelardz23 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-18-2003 19:46 |
5110 and 6210 charging problem? | Abelardz23 | Sim Cloning and Scaning | 2 | 10-22-2003 16:33 |
OFFER FOR NOKIA 8310, 8850, 8250, 8210 ,9210 , 3310 AND EMMI BOX(16MB) AND DATA CABLE | xpmobile | Main Sales Section | 1 | 11-21-2001 23:33 |
